Well the 352 in my 65 is getting tired. So my question to you guys is do I rebuild the 352 or replace it with a 390 or 460??
I have a opportunity to buy a rebuild 460 for a great price.
390 or 460 ?????
fire truck
66camperspecial
William-in-St George
FE vs 460 swap
I held off on the 460 swap because it required a matching trans (C6). Honestly I wish I'd went to 460 sooner and saved a bunch of bank. Rather than a rebuilt 460 I's suggest you locate a 460 power train from a F250 or any 460 powerd van. This gets all the bits and pieces you wil need. Current project uses a 460 train from a 80's something van. You will ned to get the correct Ford motor mounts or aftermarket and convert the shift shaft in the trans to match your column shift linkage. Assuming you are talking automatic. Not up to speed on any of the manual transmissions.
William-in-St. George
