Can't get c6 to fit
ethan_lanning
Can't get c6 to fit
Post by ethan_lanning »
So I just dropped a 390 in my 65 f100 2 wheel drive and I have the c6 sitting under the truck on a tranny jack but I can't seem to get the bellhousing between the crossmember and the cab? Is it just me or is there not enough room for the bellhousing?
http://www.supermotors.net/vehicles/reg ... 6959/57442
fire truck
Post by fire truck »
cut the rivets and remove the crossmember....or pull the engine out and put the trans back in. or my favorite way, pull the cab off, it's much easier to put in that way, you just need a lift or hoist.
MadMaxetc
Post by MadMaxetc »
If you don't stab it in from the front, you have to take the crossmember out. BE SURE TO PUT IT BACK IN! Despite what some say, you need it. You can put it back in with grade 8 bolts.
My Build Thread
bluebolt
Hump
Post by bluebolt »
You are also going to need the C6 hump from a 67-72 truck.
Re: Hump
bluebolt wrote:You are also going to need the C6 hump from a 67-72 truck.
AH! Bugger!, that`s one thing I didn`t try in the fitting stage! :(
but mine is a 351 Clevo!
ezernut9mm
Sweden
Post by ezernut9mm »
got a light mac?
ezernut9mm wrote:got a light mac?
:lol: yeah!, I could decide where to put the lighter! :lol:
ethan_lanning
Thanks for the help guys...I just got done pulling the motor back out and installing the tranny from the front and got the motor back in and bolted up to the tranny
cdherman
Post by cdherman »
I was just thinking -- grinding off those rivets and replacing with bolts should be standard proceedure and recomendation to anyone doing a frame off restore. It would have SOOOO much easier to have done that when the frame was just sitting there.
1683
Planned/considered upgrades:
Great idea Doc. I am going to do that on mine.
Alan, what ARE all those matches for? TR
Rest in Peace Cam
65 F100 Flatbed
64 F100 Short Styleside
63 F100 Short Wrongbed
61 Shortbed Uni Parts Truck
  • May Angels Fly With You
    Where Ever You Roam
    And Guide You Back Safely
    To Family And Home.
Max
Post by Max »
How to Speak Australian...
"Illuminated switches"
Uncle Skip
Post by Uncle Skip »
Guys, a general thought on mounting transmissions.
On the automatics where you have a one piece transmission body and bell housing, use two grade 8 studs in the top of the motor so they can help guide the transmission in when you stab it.
For standard transmissions, use 4 grade 8 studs in the bell housing to help align the input shaft splines to the clutch disk.
The studs help hold the transmissions in place so you're not trying to align everything and hold it up in place at the same time.
U@ss
jhewitt
wHEN PUTTING IN 1989 aod INTO 65 f100
Post by jhewitt »
WE DID THE SAME REMOVE THE RIVETS IN THE CROSS MEMBER AND REPLACE WITH GRADE 8 BOLTS.
ANOTHER MADE A >>GREAT<< SUGGESTION WHILE HAVING STRIPPED TO FRAME DO IT THEN.
Griffin GA 1965 F100
Have 3, one daily driver others in different state of repair/disrepair
Truckrat wrote:Great idea Doc. I am going to do that on mine.
Gary,so I could show how many holes the PO put in the dash!
