Brake anxiety
Brake anxiety
Dreamed I was driving in Chicago with some old pals and my brakes didn't work...Granny gear was working as I dodged cops and fire trucks !
Maybe I should go thru 'em! Ya think?
I think F100 obsession is getting serious !
- Uncle Skip
Disk brakes.
Disk brakes.
Disk brakes.
They are available for Slicks.
They are not expensive.
They are cheaper than repairing a crushed Honda for some idiot that pulls in front of you.
Cheaper than replacing your Slick.
Disk brakes.
U@ss
Disk brakes.
Disk brakes.
Disk brakes.
U@ss
- FORDBOYpete
I just got home from picking up new shoes and wheel cylinders for all 4 wheels of my 62 (had to go to 3 different to parts stores to get it all, lol). I already upgraded to a dual master cylinder. As everyone else said DISC brakes! but if it is not practical right now for you to do that at least do what I did and make sure the drum system is working at it's best.
Well fixing my brakes came to a halt (pardon the pun), gonna have to get new drums for the front. I will be back on some othrr projects with the truck while I wait for them to arrive. I could either not get them locally or the $ for them was way out of hand. LMC seems to have the best price for new ones so I will probably get them from there. I can't order them til Tuesday so I will be checking around elsewhere in the mean time.
- Truckfarmer
Greg,it seems to me that right now would be a good time to get the disk brakes. Take the drum parts back, cancel the LMC order, and contact ECI for disk brakes now. If you are anything like me, once the brakes work OK, disks will be put on the back burner, maybe forever.
- Uncle Skip
Greg.
I second TruckFarmer's opinion.
The cheapest I've seen those replacement drums is $100 American money each and that doesn't count the hoses, cylinders, et al. (They ain't even American made.)
The complete ECI kit costs in the neighborhood of $400.00.
Trust us, it's cheaper to go first class and get it right the first time.
If you have time and money to do it over, why don't you have time and money to do it right the first time.
U@ss
U@ss
blackagatha
blackagatha
- Truckfarmer
This topic came up in chat Sunday night. After some research, we found that ECI has gone up in price on their basic kit (just the brackets and spacers). The newest issue of Custom Classic Trucks has an ad from Classic Performance Parts. CPP has a special right now of $85. Then you buy the rotors and calipers from your favorite parts store and hopefully save some money on the parts and on shipping.
shawns fords
- Johnny Canuck
Shawn I thought you lived inthe dang Rocky Mountains
You never smelled anything like red hot drum brakes coming down the Logan or Roger's pass, and then having the sick feeling that you aren't gonna stop before you plow into that car ahead of you.
I am with the others. Get the kit. Might cost you an extra hundred now, but it'll be worth it forever..
shawns fords
I just got mine on the road. I had decent drum brakes on the back but discovered a leaky cylinder up front when regreasing the front axle bearings. I called the parts store for parts and I knew I was in trouble talking to them when he asked the engine size. Well they was going to have to order and it was going to be a few days. I wanted to get it on the road the next day so I went out back to my parts truck. The P.O. was fixing it up and had just put on a new wheel cylinder and brakes. So I removed them and they are on mine. I am using the original drums for now but I did change to a 68 mustang dual MC. I also changed to a pedal mounted brake switch. As far as the breaking goes it stops better now than it ever has. I think it even stops better than my sunfire. The one thing I don't like about discs it seems to need brake shoes a lot more than drums to me. I tried all kinds of rotors and brake pads. I even had this problem with other autos I have owned. I do not have a leadfoot and the way I drive I don't hit the brakes alot compared to others. If funds permit one day I may due the disc conversion but for now I will use the drums. Thanks to the being laid off and only getting about half the pay I was
plus the cost of everything going up sky high I will have to wait on this. But the brakes I have do stop extremely well. And I keep a good distance between me and the guy in front of me.
I called CPP yesterday, the brackets "start at" $85 - $95 for 57-64 F100s. I ordered them while I was on the phone with them. Works out to be $10 cheaper to convert to disc than to repair the drum brakes. You will have to wait about 2 weeks for the brackets to show up. If they use the same parts as ECIs setup which is likely you are looking at mid 70s GM full size car calipers - $20 each without core & $20 for the pads + a brake hardware kit for them, mid 70s F150 Rotors $27 (I have heard that some kits use 88/96 rotors), Don't know about the wheel bearings yet but lets face it they are cheap for everything and most of ours need them replaced anyway if we have an original truck. I had stumbled across an online article Where a guy had done this with ECIs kit online, pretty darn simple. Sorry didn't save the link, but I did save the parts list. Here it is just for fun.
Parts from local auto parts
Year and Make Mfr and Part # Price
57-64 F-100 BCA Front Inner Bearing Seal 44053 23.99 per, need 2
76 F100 2WD Raybestos Front rotors 5006RGS 42.99 per, need 2
76 F100 2WD Cardone POWER Dual Master Cylinder 101617 16.99 plus core
76 F100 2WD Cardone MANUAL Dual Master Cylinder 101617 14.99 plus core
76 F100 2WD Dorman dust cap 13973 3.99 per, need 2
76 Chevy Camero BCA taper bearing A2 (Outer Rotor Bearing) 9.59 per, need 2
76 Chevy Impala Cardone Calipers 184035 Right /184036 Left 12.99 per + core, need 2
76 Chevy Impala USA Brake Lock 14572 3.59 per, need 2
76 Chevy Impala Tru Torque brake hose H80965 16.96 per, need 2
76 Chevy Impala your choice brake pads > call
76 Chevy Impala Dorman Banjo Bolt 4842001 3.29 per, need 2
So because you don't use them that makes them better??shawns fords wrote:nope johnny matter fact I hardly ever use brakes when going down hills only to slow down for turns...
Rear drums only do about 20% of the braking, so 80% less wear on that point alone. Now think about how much more metel is in a Drum than a disk. More metel means you can hold more energy, (in the form of heat) but the drums can not cool as fast as a disk, so they are more likly to fade. Going back to your first point, this is why they seam to have more stopping power, they ARE better at first, but then they fade fast, and that is not good.shawns fords wrote:...all that disc brake upgrade is a bunch of bullshit to me, hell ive replaced more cracked front rotors and burnt up pistons in calipers than ill ever replace rear drums.
Shawns Fords,
You are intitled to your opinion...I just disagree. Nothing I said was ment to harm.
Have you compaired the surface areas of the Pads (disks) to that of a Shoe (Drum) they are a little more than half. So it would make sence that you would have to replace them twice as much. There are a lot more things that impact the wear, but that is a big one.willy3486 wrote:The one thing I don't like about discs it seems to need brake shoes a lot more than drums to me.
YIKES!!! If we put on GM parts will we get excomunicated from slick60s?Greg D wrote:
Seriously do you have to change rims? I remember the Dodge being the same but what about this upgrade? I have original rims and prefer not to change. For now the brakes on mine are excellent and I probably will not put on more that 50 miles a month at the most. My truck stops as good as my sunfire the best I can tell. It seems like I am constantly putting on new pads and rotors. I do not use the brakes that much either. I am more reserved than most in the way I drive. Eventually if I inherit millions,fat chance or the economy gets better for me I probably will switch. But I will use what I have now.
