61 Short bed unibody project in Nor Cal
rbeck204
Post by rbeck204 »
Here is a fairly recent picture of my truck. I bead blasted and epoxy primered the truck. It is in outstanding condition. I have done absolutely no bodywork on it and I intend to leave it primered.
The doors and glass are in now.
It has a 78 Camaro subframe in the front for power steering and power disk brakes and a lower stance. I also used the 78 Camaro rear end and flipped the hangers and used the stock truck springs.
It has a low mileage 2006 5.3 Liter Chevy fuel injected all aluminum V8 with 4L60E overdrive trans. Computer has been re-flashed to eliminate smog codes and improve performance. I used a black box to convert the electronic speedo output (VSS) to run the stock mechanical speedo.
All stock heater, wipers, light switches etc but used a kit to re-wire the entire truck.
I used the stock tank and ran a return line back for the fuel injection.
18" tires and wheels with Ford logos in the center caps.
It runs now and I am just shaking the bugs out.
61 T Bird Convertible
1953 Ford Customline 2 door
twistedfreak
Post by twistedfreak »
looks like a very nice project you have going on there id like to see the picks of that 5.3 sitting in there its def different route to go on the drive train.
""WE THE WILLING, LED BY THE UNKNOWING, ARE DOING THE IMPOSSIBLE FOR THE UNGRATEFUL""
rbeck204
picture of 5.3 vortec in 61 Unibody
Post by rbeck204 »
I used the stock motor mounts from the 78 camaro sub frame but raised them 1 1/4 inches so the AC compressor would clear the crossmember. I also used the stock Camaro trans crossmember (it is the same width as the truck frame so I set it in the frame rails and bolted it in). The engine was a truck engine out of a Z71 Silverado and the right side exhaust manifold turned toward the frame and would not fit. I used shorty headers from Summit and fit was great.
slickmainer
Post by slickmainer »
i know some get all bent about something other than a ford in there, but I think it looks pretty good and clean.
--Gregg--
you can't get there from here
deflaytedwayz
Post by deflaytedwayz »
looks pretty good! maybe i'll see it at some shows sometime.
