Wiper Motor Bracket Removal?
PDXFactory
Post by PDXFactory »
Hey guys,
I've been searching all over, but can't find an answer to my question here. I'm attempting to sort out all of the minor issues on my '66, and part of that is to get the wipers working well. I'm likely going to be swapping in a delay box, but first I need to deal with a bunch of slop in the system.
Can someone tell me the method for removing the wiper motor and bracket assembly? It appears that all three mounting bolts for the bracket have regular loose nuts on the backside - two of those in the cowl vent area that is almost inaccessible. Assuming I'm right and these nuts aren't captured, what's the method for holding/reinstalling 'em? Looks like I might be able to go through the firewall plug, but it doesn't look easy! (Also wondering if maybe mine isn't quite stock anymore - wouldn't be the first thing I've found that has been 'modified' in its life!)
Thanks!
~PDX
Brian Taylor
Post by Brian Taylor »
From under the dash you should be able to take out the 3 bolts holding the bracket. Nuts are attached to the body. First though take the clip of the linkage at the back of the motor and bracket. It should just slide off but do not loose it.
1966 Ford F-100 LWB 300
PDXFactory
Thanks for the reply!
I forgot to mention that I already removed the lower one that is accessible in the engine compartment, and it wasn't attached to the body...which is why I was wondering if the upper nuts were different.
I'll give the top two a spin and see what happens...hopefully this isn't a previous owner modification!
They should be captive nuts in the firewall, but don`t burn them out like My PO did! and then siliconed one back in! :roll:
PDXFactory
Well, turns out that my truck doesn't have any welded / captured nuts left. I've successfully removed two, but gave up on the last one after it got dark last night. The one left is the furthest one up inside the cowl vent, and it was a welded nut, but it's spinning too.
I have some ideas to fix this one for good. I'll post up whatever I come up with...
Thanks,
~PDX
