frame
goonie
frame
Post by goonie »
Since I'm taking off almost everything on my truck to get painted, is there anything that I can do to my frame (myself) to protect it against rust and to give it a good color (black)?
GOONIE
PFM-64f100
Post by PFM-64f100 »
Some people blast them and have them powder coated. Others blast and paint. And then there's some people who blast and get a rinho coating or Line-X coating put on them. I plan on at least blasting and painting my frame when I do my dakota front end replacment.
I would love to powder coat it but that's kinda expensive along with the rinho or line-x. I will have to see how much each option is when I get the frame. So long story short it's up to you which way you want to go. Oh and this would be a good time to change the gas tank (Either Mustang tank or Bronco II tank) if you haven't done it already.
goonie
frame
Post by goonie »
I will make sure to put the gas tank on. I also have buy new wood for the bed after I cut the metal plate from the side. The more I take off of this truck the more I find I should do. Not a need but a should. I was thinking of just degreasing and wire brushing the frame and painting it myself. Does anyone know of a company that sells the rollpans for the 66 step. Thanks for your advice
GOONIE
kraquen
Post by kraquen »
this past weekend I started doing the scrape & paint on my frame... I had quite a bit of rust (including some flaking in the rear shock mount brackets)
i used a 5" wire cup in a 7" angle grinder to get all the loose stuff off. Then I washed it with soap and water... then i sprayed "metal ready" from por15. Then i painted it with por15.
I'm about halfway done with my frame at the moment (the top half).
jason
Johnny Canuck
Post by Johnny Canuck »
[albumimg]46[/albumimg]
[albumimg]47[/albumimg]
sandblasted and painted with por 15.
Tough as nails.
