Doc Pepper wrote:I wonder how tough it would be to BUILD a carburetor?
Why you don't see carburetors anymore!!
Re: Why you don't see carburetors anymore!!
Someday I'll get another slick
- DV65CustomCab
- Johnny Canuck
Were you phoning my local NAPA doc?
Phone conversations yesterday went like this
JC: Hi I need front brake Hoses for a Bricklin
Parts place: Brickland? who makes those
JC: Bricklin. They were made in Canada between 1974 and 1976. Last independent Canadian Automaker.
Parts place: Canadian? I dunno where you are gonna get parts for that
JC: I figured I'd start in Canada. Same Kelsey-Hayes brake hoses as a '74 Javelin
Parts place: Javelin? Who makes those again?
JC: American Motors. You know, Jeep, Gremlin, Hornet?
Parts place: You want heater hoses?
JC: yeah i want heater hoses. That's why I am phoning a Parts place, I can't get heater hose by the foot at 100 stores in town.
Parts place: OK... Jabberwocky... who makes them again?
JC: -click- ... dialtone
I don't neccesarily think fuel injection is an improvement,over carbs. I've seen older big cars get gas mileage that would nearly equal small economy boxes. This was rare, but did happen. So what's the difference, I can't tell you. Why did some of these cars get extremely good mileage and some poor? If I knew the answere to that, I would be a wealthy man today. Fuel injection has the potential of being both more consistent and get better fuel economy, but doesn't neccesarily do so. I don't think the programing of most cars is fine tuned enough to get optimal fuel economy, although it is getting somewhat better. The advantage to fuel injection is in the feedback from the sensors. This allows for the computer to adjust ratios on the fly. This is all well and good, but garbage in means garbage out. To add to the list of woes, not all parts are equal. Ace, a local mechanic, and the best in this area when it comes to electronics on the newer cars, told me recently of a problem he had had with an oxygen sensor. Truck came in with a problem, which he traced to a lazy oxygen sensor. By lazy, I mean the sensor was slow cycling. He replaced the sensor with a new Borg Warneer unit, still not right, also was lazy. Replaced that with another Borg Warner sensor withsame results. The units were better than the original but still lazy, and not functioning at best value, and truck was still not running right. He finallly ordered a new genuine part from the local dealer, and it functioned right and cured the problem. The difference in cost for curing a carb problem and a fuel injection problem, is often astronomical. Same with the fuel pump on fuel injection. Fuel pump for carb 20 to 30 bucks, as to 60 and up for fuel injected. For what it costs to get a Fuel injection problem diagnosed, you can often buy a rebuilt carb. Then you costs of fixing fuel injection problem can go from 30$ to the extreme.
As to jetting, I have a small quantity of jets that I've had for years, but have no idea what these fit, all new out of package. I also have some carbs rebuilt and new, that I have taken some parts off of. I believe these may be for the 240, but not certain. Deffinately 6 cylinder carbs.
My opinion on fuel mileage 19 to 21 is good for a flying brick. If you don't have an overdrive transmission, you need one, for better mileage and less wear on engine for the highway.
Don't know if you've done anything for the spark, but high voltage coil, and and wider gap on theplugs would help, along with duraspark distributer. I have two out of 300 sixes, which should work in the 240, but not positive.
One thing has always bothered me about the Ford sixes. The intake manifold. How can all cylinders be getting the same fuel ratio at idle, when the gas goes in the middle? Raw gas weighs more than air, and has a tendency to drop out of the mixture. This would cause the middle cylinders to carry the load at idle, in my opinion.
- FORDBOYpete
I HEAR Y'All
I would add it's not limited to Carburetors, it's Auto, Truck, & equipment parts across the industry in general.
It reminds me of some latter day "Hex Spurts" I run across on other sites who think they're doing me & the rest of the world a favor with unlimited, published but incorrect "pseudo Knowledge" and jaded or wrong opinions about all "Automania" Bar None. I used to let it bother me. But Hell! if it was a Broadway Comedy Show, tickets would cost upwards of U.S. $100 each. I have started to laugh at them in & to their faces like below.
I tried to purchase a front axle & w/Cardin Joint for my Aerostar AWD beater. That was like a Comedy Central experience. I finally took the guy outside & showed him my Aerostar. That;s how I found out the vehicle we bought off a dealer lot in 1994 Brand New is actually some sort of custom alteration that somebody did for FoMoCo.
You know, like Marmon Harrington used to do in 1930s & 1940'S ?
I showed him an OEM Manual & Pouch. So he says "They did a great job printing up that owners manual too."
When I got axles from Axle House, for $89 each, I took them to show the jerk where it said; Ford Aero 1992-6 L/H Axle, right on the box and asked him how it felt to be only person in the world not to know how to read a catalogue. . . . . His answer "Oh we use computers now"
Guess he doesn't know data in his computer's digital format catalog he's not figured out how to read, surf & research in, Huh? .
I Love It
FBp
I Love It
FBp
Change is the Only Constant
- bobenhotep
often older carbs before the emissions era were jetted leaner than fi is set to run at today. they were sometimes set just rich enough to not burn the exhaust valves. fi runs at a point where on average it runs 14.7-1.it does this by switching rapidly between like 12-1 and like 17-1.if your o2 sensor is bad, then it just hangs out at 12-1. I usually try to run a huge pcv valve and jet to run just rich enough not to run hot or stumble...
My '63 short wrongbed
"The Iron Rhino"
-300-6 choke tube repair
-duraspark II/ HEI
-turn signal indicator fix
"The Iron Rhino"
-duraspark II/ HEI
