302 flaxplate
302 flaxplate
Hey guys I have a question for ya'll. I'm putting in a 302 with a c4 transmission, into my 66. I have to buy a torque converter, flexplate and starter. I didn't get these parts when I bought the motor and trans. I have been looking on the internet trying to find what I need, but all I'm getting is confused! What's confusing me is terms such as balanced and imbalanced, number of teeth and such.
So now I don't know what I should be buying. You guys have any suggestions? Is there something I should know about my motor and transmission before I can make a decision? Thanks everybody.
Thank you Mr. Pope, I did see those numbers mentioned. I reckon I need to find out the year of my motor. What about the number of teeth on a flexplate, does that factor in anywhere? Yhanks again.R Pope wrote:You have to know the year of the 302 to get the right flexplate, there are two different weights, a 28 and a 50 oz., I believe.
- Uncle Skip
The 302s changed balance somewhere around late 1981...If its older than that it is a 28oz balance..If its newer than that it is a 50oz balance...The number of teeth on the flywheel/flexplate is also very important...Generally trucks use 164 tooth which is a little bigger diameter than a 157 tooth...Cars used both sizes with the smaller 157 tooth usually in smaller cars like mustangs...Do you know what the engine and trans were out of?
1965 F100(the wifes)
1968 Mustang 408W stroker
bunchoftrucks
302 flaxplate
Windsor Fox is a great reference source and is very helpful. I used them for info and parts when I did my 302/AOD in my 64 shortie. What shifter are you going to use? I used the LOKAR Nostalgia shifter and am very pleased, no problem in 6 years.
Don't know about the motor, but the trans came out of a mustang.frdnut wrote:Do you know what the engine and trans were out of?
I haven't decided on the shifter yet, but pretty sure it will be a floor shift.bunchoftrucks wrote:What shifter are you going to use?
I did find out with you guys help, that the motor was made in 1974. So it used the 28oz flexplate and harmonic balancer. I also read that the crankshaft is part of this equation. I guess to be absolutely sure, I need to drop the oil pan and see if I can find some numbers on the crankshaft and check. I want to be 100% sure this stuff is balanced like it should be. I haven't checked the HB yet to make sure it's 28oz.
Thank you guys for helping me.
fire truck
I've never heard that the year mattered, only roller or non roller. I have yet to see a non roller 5.0 with a 50oz on it. You're right, you need a 28oz. The c4 came with both big and small bells. The mustang c-4 is a small bell, so you need a small 28oz flexplate.
When I swapped a 1988 mustang roller motor into my '81 Short box back in 1991 or 92, I called Ford Motorsport, and they explained the early/late balance deal, and told me how to distinguish one from the other (if only I still remembered:)....in the end, it turns out the flexplate off my original 302 was correct for the roller motor, which had come out of a stick car.....so the flywheel was of little use with my C6:)
James
James
fire truck wrote:I've never heard that the year mattered, only roller or non roller. I have yet to see a non roller 5.0 with a 50oz on it. You're right, you need a 28oz. The c4 came with both big and small bells. The mustang c-4 is a small bell, so you need a small 28oz flexplate.
I was in the same boat a while back found this link quite informative...
http://www.rowand.net/Shop/Tech/FordFly ... plates.htm
fire truck
