Hey everyone,
My truck is missing the rubber "strips" that seal the fenders and firewall so as not to allow and road grime, water, rocks, etc get throw up from the front wheels into the engine compartment. These are the strips that are "stapled" to the fenders, not the straps that hold the fender to the firewall.
Anyway, I hope I've described what I'm talking about well enough... What I'm wanting to know is where I can buy replacements or in absence of replacements being available, some ideas as to what I could use as a substitute? The material needs to be stiff enough to hold it's shape, but not too stiff or thick.
Let me know.
Cheers,
Dion
Fender to firewall rubber strips?
- qwertyd10n
- Uncle Skip
Dion. If you can find someplace that sells industrial gaskets (like for chemical plants, manufacturing facilities and the like) buy some 1/8" neoprene sheet and make your own.
Looks pretty cool with SS boat style trim washers and screws for attachment.
It is the same material used in flexible exhaust hangers. Get a couple of those and cut to size. I just took this picture last night when I removed the front end so you can see what they look like.
1991 Porsche 964 Cabriolet
2006 Cheby Silverado
- Uncle Skip
- qwertyd10n
Hey Uncle Skip,Uncle Skip wrote:Dion. If you can find someplace that sells industrial gaskets (like for chemical plants, manufacturing facilities and the like) buy some 1/8" neoprene sheet and make your own.
Not sure I know what boat style trim washers are... Can you give me an example?
Cheers,
Dion
Rubber strips
Hey I am replacing mine too. I have the old ones and what I thought I would do is cut new ones out of a cheap black rubber floor mat.
Hal C
- ezernut9mm
i'll bet he is talking about those cupped washers that the screw or bolt heads nestle in.
'66 F100 --
'78 Bronco --
