shortening a steering column,help!
SAD66
Post by SAD66 »
I have a 66 f100,manual trans and steering. I salvaged a power steering box and steering column from a 74 f100 auto trans. The column turned out to be junk, so I was going to shorten the 66 column. Does anyone have any experience doing this that they could help me with?
66 f100 352,3spd; 2000 f-250 diesel
BigMike
Post by BigMike »
Just use the shaft from the '74 if it is still good.
FYI - the column doesn't have to be shortened, just the shaft. You will need to get a collar for the end of the shaft to replace the clamp. There should be one on the '74 shaft.
Take the shaft to a PROFESSIONAL welder. They need to remove the joint at the end of the shaft, cut the shaft, and re-weld the joint to the end of the shaft EXACTLY perpendicular to one another.
Oh yeah, replace the bearings while you're in there.
I just went through the same dilemma myself. I'm using the '71 column tube, shaft, and the manual trans collar from my '65. When I install the C6 auto in my Slick this summer, I can put all of the automatic shifter stuff back into the column.
1991 Porsche 964 Cabriolet
2006 Cheby Silverado
