what Oil pan should I use?
*1bad66*
Post by *1bad66* »
Ok, I finally pulled the engine out of the 66 and found that my oil pressure problem was just the pickup tube clogged with dog hair. So that was a relief. Now that I got it out I want to change oil pans because it is hard to change the oil with the stock ltd front sump pan that was on the 351w originally. I would like to put a pan off a early 70s f-100 with a 302. Thanks
66 F-100 351W
Max
Post by Max »
I had a similar question about a year ago in regards to the oil pan for a 351W and advantages/disadvantages towards front sump, rear sump, front/rear sump...? Only answer I got was they changed them depending on what vehicle it was in and where the crossmember divided the oilpan.
bertha66
Post by bertha66 »
If it will clear the crossmember, a rear slump pan from a 4x4 would be the way to go. But you need the oil pump pick-up and the main bearing cap bolt that holds the pick-up in place.
1966 F-100 4x4 390hipro
1964 Galaxie 428 ci
1967 F-100
1968 F-350 crew truck
Bodyworx
Post by Bodyworx »
Dog Hair ? .........Hmmmmm. I have had my stuff clogged with a variety of stuff but .........
Damn Dogs !!! Hahahaha !!
RED
Dirtier Than A Trailer Park Love Story
*1bad66*
Post by *1bad66* »
At first the dog hair was kind of a relief because I was expecting worse but then I thought about it and I wanted to kill the damn dog but then again it wasnt her fault I left the engine exposed in the garage. For the pan I think I am going to go to the local core supply and buy a pan for a early 70s f-100 with a 302 and if it fits Im gonna by a new pickup tube for it. I guess just trial and error.
66 F-100 351W
Garbz
Post by Garbz »
Check a 351 pan vs the 302. the pan oil seal is larger on a 351.
Use a pan and pickup from any 351 W equipped F150 F250 1980 to 96
It will have rear sump and a rear pickup tube. Plus take the oil dip stick as it will no longer be in front.
The rear sump pan is only a convienince to allow oil changes with out drooling oil all over the ford crossmember with a front sump pan.
Garbz
Johnny Canuck
Post by Johnny Canuck »
Garbz is right. a 351w pan will NOT fit a 302 and vice versa. the diameter of the front and rear main bearing caps is different.
Never mind how I know this.Image
Garbz
Post by Garbz »
John knows it the same way i learned........... :oops:
Garbz
*1bad66*
Post by *1bad66* »
Thanks guys for the info. I always thought a 302 and 351w were the same on the bottom end. I appreciate it know I now what to get. Thanks again
66 F-100 351W
kid2
Post by kid2 »
Garbz and JC, I can relate to the Don't ask me how I know that will not work answer. One of the great things about this group is no matter what mistakes someone has made someone else has made the same mistake and can help them out, like forgeting that stupid thin plate between the block and bell housing that I forgot to put in and had to pull the whole works back out on my 65 ( thanks Garbz for walkng me through that one as to where the noise was coming from ). I was not a happy camper when I had to pull the trans/bell housing/ clutch/ flywheel back out to put that plate back in and all my brother could do is laugh till I told him he had to help..................Kid
Still learning from my mistakes
65 f-100, Mostly Stock
64 F-100, 4in roof chop and on a car frame
64 F100, Project, not sure what to do with it
61 Long Uni project
79 F-250 Super Cab Long Box
74 Duster, Future Project
Dropped,Chopped,Tubbed,and Stubbed is the way to go
It is easier to ask Forgivness than to ask Permission
ripsnorter
Post by ripsnorter »
This reminds me of my current problem:
I'm sticking a 300 in my 66 to replace a bad 300. They both have the sump in the middle, which is exactly on top of the crossmember. not a problem clearing the crossmember, but its going to be hard to change the oil. I have a pan from a newer 300, with the sump in the rear.
Can I just swap pans? or is the pickup for the oilpump in the center? I dont want to drop the pan to check unless I have to, as the engine is already have in the truck.
