anybody use either of of these brake kits?
mosquito13
Norway
Post by mosquito13 »
want to upgrade the stops 1st thing. anyone use either of these kits?
http://www.ebay.com/itm/150727607703?ss ... 1423.l2649
or
http://www.speedwaymotors.com/Deluxe-Di ... layId=7689
Hot Rod Rock every Tuesday 3-5pm Eastern on http://www.wslr.org
63 f100, 64 dodge polara, 74 john player norton, lots of rd 350's & 400's,
1977 kz650 (it's a sickness...)
jwcnj45
Re: anybody use either of of these brake kits?
Post by jwcnj45 »
I used the Speedway kit on my 63 Unibody. The kit was a good buy for the price.
The Ebay one and Speedway use Classic Performance Product's brackets.
CPP is excellent (except the instructions).
I did this "How To" because of the instructions;
viewtopic.php?f=5&t=2647
mosquito13
Norway
nice greg, doing a project and taking pics is more work . thanks
Uncle Skip
Post by Uncle Skip »
I think I was the first one here to do the disk conversion on a straight axle truck and back then, the only option I could find was ECI/ Hot Rod Brakes kit. I was very happy and the kit has served me well. Some of the newer ones seem to be a little cheaper to buy and I don't have anything to compare mine to. They all look pretty much the same so go for it.
Hunter's 64
Post by Hunter's 64 »
I used the kit from performance online fit well no complaints.
Danny
JOELHEWITT
Post by JOELHEWITT »
I was wondering I did a disc conversion on my 1965 using the newer Ford spindles & Ford calipers, and I think that such a conversion as this one you state would be LESS time consuming and hassle, is there such a conversion like this for a 1965 using the factory spindles?
Located JUST SOUTH OF ATLANTA GEORGIA C.S.A.
mosquito13
Norway
ordered a set of classic performance brackets. priced it out can do better that way and get to sling some cash to the local parts counter getting the calipers and rotors ect... thanks for the heads up on the brackets. have used scarebirds bracket kits on my 64 galaxie xl and the 64 dodge 440 with good results.pick out the boooster/master & the line lock tommorow and order them up .
rbeck204
Post by rbeck204 »
Just installed the Speedway kit on my kid's 64 and it all fit perfectly. Had to grind a little off the calipers to clear the brackets but the kit instructions said I might have to. The brakes work great and I also installed a master cylinder and booster I bought on e-bay. Together I have safer brakes for my college bound, slick loyal, kid. I recommend it.
61 T Bird Convertible
1953 Ford Customline 2 door
Rusted64
Post by Rusted64 »
Anyone install the speedway kit without a booster?
Does it still work well?
I would assume it is still better, but wondering if the booster makes the biggest difference.
J
1964 F100, 292ci
1963 Buick Wildcat, 401ci
They just don't make them like they used to.
lennys61
Post by lennys61 »
I was hoping there was a cross reference for things like Master cylinders, rotors and calipers, and you could just buy the brackets for the calipers.
cwindsor
Post by cwindsor »
DO you have that post with the pictures??? I have the speedway kit and was going to install it... It would be easier with the Pictures.
lennys61
Post by lennys61 »
are the kits the same ones that are sold in LMC Truck and Sacramento Vintage Ford?
olliesshop
Post by olliesshop »
Does anyone make these kits (as in does anyone have any experience with) for my '61 8-lug F-250? I hadn't thought about upgrading, but they sure would be a nice safety upgrade? I'm going to start searching ... :D
Tim - 1961 F250 Uni
Hunter's 64
lennys61 wrote:I was hoping there was a cross reference for things like Master cylinders, rotors and calipers, and you could just buy the brackets for the calipers.
In the paper work for the Oline Performance kit it list replacement parts for some
Rotors: 73-79 f100/f150 2wd
Calipers: 71-76 Chebby Impala,Belair,Biscane
Buick electra , LeSabre, Roadmaster, Estate wagon, Park ave,
Bearings and seals:
Outer - A2/set 2 used on 64-77 GM inermadiate cars
camero,firebird, chebby, monte carlo ect....
Inner- A13/set 13 standard inner bearing used in ford rotor
Seal - National 44053-standard seal used on 57-64 ford 1/2 ton pickup
