hey whats this??
hey whats this??
Hey guys!! im currently poking around getting ready to change out the gauge cluster and i saw this. It looks like some kind of switch? maybe brake? it has a tab with a spring that slides over and maybe hits a contact? it does have 2 wires connected on the back. im thinking its some kind of brake switch but nothing is connected to the brake pedal. Before i parked it for the winter my brake lights didnt work with the pedal. any guess's? Thanks!!
- IMAG0277.jpg (66.33 KiB) Viewed 1045 times
- IMAG0278.jpg (91 KiB) Viewed 1045 times
1966 F100
1971 honda CB350 Twin
2004 Harely Sportster 1200C
slickstysix
Re: hey whats this??
I'm no expert, but it looks like a neutral safety switch for an automatic with on the column shifter.
1966 SB, 2WD, 390FE, 3x2 6V carbs and intake, 3 on-the-tree (for now).
- Power brakes
- Pertronix electronic ignition
- Ron Francis wiring throughout
- DJM drop beams
- Halibrand Sprint 17x8 wheels
- Power brakes
- DJM drop beams
it is an automatic, but i still dont see how it works. theres nothing that i can tell that comes in contact with the arm. and please forgive me?! this is my first truck and im still trying to figure everything out.
1966 F100
Yea that is a neutral safety switch!! Same thing on my
1971 F100! Looks like your missing a part on the Column! There is a little arm that sticks out of the column that moves that peg on the neutral safety when your go into park and drive R N! Mine on the 71 has been bad for years! So I just took a wire so it would stay in one place so I can start my truck in ANY GEAR! Just got to watch the kidos if ya have any!
1971 Ford F350 DRW, 1971 F100, 1966 F250 4x4, 1966 Galaxie,
1962 IH R-185 Firetruck, 1960 F750 FireTruck, 1960 Gmc 6000 Firetruck
1959 Ford Custom, 1940 Ford Truck
William-in-St George
Neutral safety switch. Should have 4 wires one set for no start in gear and the other for a backup light. There should be a small lever clamped to the shift tube that actuates the switch. If your truck is standard transmission you can remove and toss this. If you drive an automatic you may have a neutral safety switch on the transmission. If your truck starts in gear replace this switch, install the missing actuating lever and re wire the truck so this safety feature works like it should. Stop light switch is likley hydraulic and mounted near the master cylinder. Many here change these hydraulic switches out for a mechanical switch. Not hard. Do a search for stoplight switch and you will find the information you need.
William-in-St. George
- 6166 Junkyard Dog
It's what you call a neutral switch pointer, snaps in on shift tube and is spring steel
Kathy
Now Cooper will try his best
Whatever you do don't flip that switch... It makes all the j-nuts on the truck rust up and break off when you try to remove them!
