Tachometer?
jaythejug
Tachometer?
Post by jaythejug »
Hey guy's I have a 66 with the original 352. I would like to install a tachometer. reason being i would like to see whats going on at what speed and maybe from there i can make a plan for my next move.
What gauge would you all recomend and is it very difficult to install. I am working with points.
Thanks all for your input!!
1966 F100
1971 honda CB350 Twin
2004 Harely Sportster 1200C
cooter
Re: Tachometer?
Post by cooter »
auto meter makes good gauges, wiring is easy, one power wire, one ground, i light wire and 1 wire to the negative side of the coil and you are done
jaythejug
Re: Tachometer?
Post by jaythejug »
for some strange reason i thought it would be more difficult to connect. Thanks cooter!
1966 F100
loveoftiki
Re: Tachometer?
Post by loveoftiki »
I dig my Moon column mount tach. It was relatively cheap and looks cool
POOR BOYS C.C.
SINS OF STEEL - DAVISBURG, MI www.sinsofsteel.com - Look it up!
