Ok, I have a 91 Caprice that my brother had a little front end dissagreement with something solid. It pushed the grill, radiator core support, hood and driver fender back . Not too bad, it's fixable with some replacement cosmetics. The fan shattered the shroud but clear from touching anything else. It should at least start up, but it appears to have no fuel supply.
Is there a cuttoff switch/relay in the trunk on this model, and if so where?
thanks.
