carb rebuild kits
donald luster
carb rebuild kits
Post by donald luster »
I have had several weeks of not being able to get a carb rebuilt kit for my 63 holly 1 barrel carb. Finally ordered from Ford parts obsolete in Ok Is there a better place to get carb kits? I tried several parts houses but not luck.
Re: carb rebuild kits
I bought one from autozone last year
61 1 bbl
I was satisfied with it, after over a year, still good
LM14
Post by LM14 »
NAPA should be able to get one for you. That's where I always got them.
66fordtrucknut
Post by 66fordtrucknut »
I ordered mine directly from Holley, I have a Holley 2043. I had a hard time finding one. The 2nd time I rebuilt it I got a napa kit, the check ball was bigger, and the truck wouldn't run for nothing, tore it back apart and then noticed the difference. put the old one back in and was good to go. IF I did it again I'd prob. go thru Holley, couple bucks more but right parts and pieces.
Charlie
62' SWB uni 223
66' F-100 Short/wide 352
78' F-350 dually dumpbed 400
12' F-150 5.0 3:73 LS
donald luster
How do you order from Holly. Is it on line on computer?
