front clip bolts??
eddieschopshop
front clip bolts??
Post by eddieschopshop »
have my front clip off my 64 taken off.. in the process a couple of bolts broke,stripped or got misplaced..
i want to put the the front end together soon and i was thinking of just replacing all the 49 year old bolts/nuts..
the main ones that i would like to replace are the ones where the front fender bolts on to radiator support. the nut is somewhat attached to radiator support. i have no idea what that type of nut would be called..
does anyone have an idea what size those are? or what there called?
thanks in advance
eddie
Re: front clip bolts??
Post by rickairmedic »
Eddie this might help some :D.
viewtopic.php?f=5&t=29735
eddieschopshop
thanks.. i will check that out
i found some on grainger but dont too sure on the size..
but there called U-NUTS
Uncle Skip
Post by Uncle Skip »
5/16-18 or if they're fine thread, they're 5/16-24.
While you're there, might as well pick up a half dozen 5/16" cage nuts. Might save you a trip!
kstones63
Post by kstones63 »
You might check at www.mcmaster-carr.com They probably will be cheaper than Graingers.
Kevin
kstones63
63 F100
29 Ford Sedan Delivery
99 F250 PSD, 4x4, CC
95 F350 Flatbed Dually Diesel
eddieschopshop
awesome fellaz great info :mrgreen:
UNCLE SKIP- thanks for the sizes.. im outta town for work and its not like i can go measure.. and since i was thinking of ordering today or tomorrow.. i will probably order a dozen of each.. just in case..
KEV- i will def. check that out out.. especially because the company i work for has an account there.. ;)
eddieschopshop
gotta luv mcmaster... easy to navigate and prices are very reasonable..
i just place an order for the u-nuts and matching bolts..
thanks again fellaz for all the info..
