With the front holes the way they are, I couldn't find anything to cover, so I made a slightly-over-cab-high shell for my short uni. It stands about 6 or 7 inches taller than the cab. Made a base to cover the holes and match the curve in the cab back out of 1/8 X 3 strap, the rest of the framework is made of 3/4 thinwall square. Covered with alum sheet from a 60s overhead slide-in that I found. It weighs about 300 lbs. Not quite what you are asking about, but trying to show if you want it, you are going to have to make it. I don't think there is anything available for these pickups. Also, if you get up to high, may have a problem with not having any swaybars, mine isn't heavy enough or high enough to cause any problems.
Fred
I remember seeing a camper special a few years back. It had a camper that was optional from ford. Apperently Ford offered a camper direct from the factory or something. It was ugly. Forgert the bed camper and go with a vintage camper like me. I got 2 vintage ones now,.
I have a 66 f100 and enjoyed (for the most part) camping with a cab over camper for 6 years. I did learn some things though: Make sure that the tires can take the extra load (took three trips for me to learn that one), Dont over load the camper (the race that holds the nearings in the rear end heats up and slides down and that took only two trips. A 4speed and over loads help. Probably the dumbest thing about what I did though was using the original brakes. Dont ask me how I know that brake fluid boils and why I had to have a block of wood in the cab. Gosh I cant believe I did that and am here to tell the sordid tail.
Garbz wrote:I have the 63 AMT long bed with the optional ford slide in camper shell..
Really ugly bugger to.
Garbz
HOW do you get in the upper section? I have that kit, too. Unbuilt in the box. The 1967 issue had the camper.
Tracy
1956 F-100 Panel w/429 (3.50 9")
1966 F-100 SWB w/351C (3.25 9" - 3.70 posi for Saturday nights)
Music City F-100's,
1965 GT-350 S/C (2.78 1st & 3.70 TracLok 9")
Music City Mustang Club
1969 Schwinn StingRay Don't focus on the destination....make the JOURNEY the adventure
