"Question For Any Econoline Guys"
Shadow
Post by Shadow »
After Years Of Chevy's & Buick's My Friend Finally Got An Old Ford. It's A 1967' Econoline Van. Here's The Problem, He Needs A New Master Cylinder And They Are Impossible To Find. I Guess They Were 67' Only On The Dual-Pot Reservoirs. Anybody Ever Used A Different Master Cylinder? Off The 67' Pickup Maybe?? Or Should He Locate A Rebuild Kit?? I Know One Of You Crafty Veterans Has Probably Dealt With This Issue. Thanks....
Fordman85
Re: "Question For Any Econoline Guys"
Post by Fordman85 »
Fanatic
Post by Fanatic »
Not sure what the Econo used but If its the same as the Fairlane (with a bolt on lid) ----just use a 68. They are the same otherwise.
Shadow
Post by Shadow »
I Saw This Page, It Looks Like A Good Option Though A Bit Pricey. "Rockauto" Has The Rebuild Kits But He May Have To Have It Re Sleeved. The Econoline Vans Are A Weird Setup. They Have The Straight-Axle With The Master-Cylinder Way In Front & Slightly Above It. Not Much Room To Add Aftermarket Parts. They Make The "Slick" Brake System Look Easy. :shock: ....
