has anybody used this frame paint?
tomrooster
Is it any good, it says no primer needed, whats better for the price if any. 109 shipped on eveilbay
1966 F 100 w/391 ft
1965 F 100 project
1958 Edsel Pacer Convertible
1953 ford Customline 2 door
1952 8N
1967 triumph Bonneville
1966 F 100 w/391 ft
1965 F 100 project
1952 8N
Re: has anybody used this frame paint?
I have not used it but I talked to a paint supply company a few weeks ago and they recommended it. They say it works well and the cost is less than por 15 because you don't need all the cleaners that por requires
- daleshotrodshop
Great stuff to use here is a video on Ted Nugents Bronco check it at about 5 minutes in. https://www.youtube.com/watch?v=OCIrOljggDA
If we learn from our mistakes I should be Einstein by now.
bruceandersson
If that's the price for a gallon, looks like a good deal. I've used Rust Seal for years with great success. The one thing that I've run into is that once opened any of these paints have limited shelf life. A gallon would be enough to paint many frames and you might end up throwing most of it away once it skims over. I've started buying more smaller cans. Cost more initially but I don't end up throwing away a half full can because its hardened in the can after opening.
Haven't head any complaints about it.
I hear about guys filling unused portions with inert gas like argon from the welder. I wonder if that really works.bruceandersson wrote:If that's the price for a gallon, looks like a good deal. I've used Rust Seal for years with great success. The one thing that I've run into is that once opened any of these paints have limited shelf life. A gallon would be enough to paint many frames and you might end up throwing most of it away once it skims over. I've started buying more smaller cans. Cost more initially but I don't end up throwing away a half full can because its hardened in the can after opening.
Nic
I used it on my trailer frame and it works great. It needs to be coated because it's not UV protected. My trailer has been sitting out for about 5 or 6 years and the chassis black paint is starting to get thin because I didn't topcoat it. I would recommend it. If you have any left be sure to put Saran Wrap between the lid and can or you'll never get that lid off again because the paint reacts with metal.
SLICKCOLLECTOR
I have used both and I prefer POR15. it is thicker and you can use it with fiberglass matt with a bottom and top coat. if you only use it to paint your frame the chasis saver is okay and flows on well IMO.
jim
jim
1966 F100 SW 428CJ C6
1965 F100 SW 428 TL sold
1966 F100 SW CVC 428CJ C6
1965 F100 SW CVC 428CJ C6
1965 F100 SW CVC 460PI C6
1967 F100 SW CVC 521 C6
1967 F350 390 4 SPEED
1970 F350 428 4 SPEED
1974 F350 428 4 SPEED
tomrooster
I ordered the paint today from JB tool website and I found the paint cheaper there also ordered a couple other things ( 2 cans spray engine enamel and 2 rolls masking tape) and got my order over 100$ and got free shipping and found a coupon for 5% off and it was 103$ total. Tom
http://www.jbtoolsales.com/
1966 F 100 w/391 ft
1965 F 100 project
1952 8N
1966 F 100 w/391 ft
1965 F 100 project
1952 8N
- slickmainer
looks like a winner to me. I used the eastwood stuff and was pretty happy with it, but I was ordering some other things so i just went with their stuff
--Gregg--
you can't get there from here
Shillinghill
The Chassis Saver works great, but for my most recent projects I have used the mastercoat system their primer really seems to make a good seal. www.masterseriescoatings.com.
just my opinion, Bill
