Not for me Tom!
got sucked in to helping someone!
he's got a 64 with the original 292 Y block with the original 4 speed
on the floor I assume!
and he want to remove the 292 and replace it with a 302?
my answer was, so long as you get the bell housing, clutch, pressure plate, etc. with the 302
his original 4 speed will bolt up to it???
Yes?
No!
if no! what 4 speed will work behind the 302?
I know there is some body still left out there and not at PATE!
Engine Swap Question
- stronger66ratfink
Miss Daisy 1966 F100 short bed custom cab 2004-2014
78' F250 XLT Ranger
13' CVO Road King
78' F250 XLT Ranger
13' CVO Road King
Re: Engine Swap Question
I think you have to do something different for front motor mounts as well, like a conversion crossmember.
www.slick60s.com/viewtopic.php?f=32&t=32284
Good reading material, might help.
Simon
65 f 100
65 f 100
Nope, everyone is at Pate
Your request will be answered in the order received next business day!
Not sure if a truck 4 spd has the same bolt pattern as a car 4 spd. Motor mounts & crossmember will be an issue as well.
Tom Williams
Truck 4 speed is a different bolt pattern than a car 4 speed if I remember correctly.
The Y-block 4 speed is a different bolt pattern than the 302 so it won't bolt up. Any 4 speed, or 5 speed originally hooked to a windsor will bolt up until the change over in late 90's.
The 302 requires crossmember and mount installs but not hard. You can check the 302 5-speed swap we did on my sons 64 at the link below for what it entailed. His was originally a 3 on the tree so your buds will be easier as far as the floor already set up for floor shift. viewtopic.php?f=32&t=32284.
Hope that helps.
________________________
EDIT: I just realized Simon had already posted our swap link. I'm not used to people remembering anything I say past Sunday.
Hope that helps.
fix the 292!
