1974 lincoln mark iv rear end
ezernut9mm
Sweden
Post by ezernut9mm »
i have a friend that is going to be parting a mark iv here pretty quick. i believe the rear is a 5x 4.5 9 inch. correct? are they desirable at all? i figured the axles and housing would at least be good for someone doing the crown vic swap in front. i will be down there in a few weeks to check the car out and see what is what. i also assume that it is a coil spring rear.
he is wanting to keep the 460 and trans, but i could probably get those too. i think they were only rated around 240hp in those years.
i did once manage to get it up to 120 but it took three miles to do it, and almost as long to bring it down to a stop. lol.
the car is a rust bucket, but actually has lots of good chrome bits and brown leather interior.
if anyone knows anything about these behemoths or wants anything off of it, let me know.
this was the car in her glory days.
6166 Junkyard Dog
Re: 1974 lincoln mark iv rear end
Post by 6166 Junkyard Dog »
Chris I have used these rears in many trucks, take all the coil spring garbage off, then weld on the saddles, original brake cables will hook up,, these rears I have seen 9" or the 9 3/4" and geared as low as 2:23 I put one in my 56 panel geared at 2:42, it would go in drive about 75mph behind a FE Motor and with that combo it average 20+ mpg,, the downside they where 5 on 5 bolt pattern but with the front ends I used I was still able to keep it all around the same,,, years ago I used to sell those wheels every time to these guys that had xxxxx trucks or the big xx cars
12649
ezernut9mm
Sweden
5 on 5 huh? Well crap. I was gonna use the wheels on my galaxie.
6166 Junkyard Dog
yes I hear you Chris 5 on 5 same as the Chevy brand of vehicles as 67/72 Chevy Trucks and the big GM Cars
12649
Tom, Chris, my 56 pickup has a 9'' rear under it out of one of those.
Has a 5 on 5 bolt pattern on it too. I plan to change it out one day and put a pickup housing
in it with the 5.5 on 5 bolt pattern so I only need one spare.
This is on my ''get a round to it'' list, but hasn't happened yet. TR
6166 Junkyard Dog
Gary my 56 has one also but many,many years ago I bought from Super Bell in Calif. a disc brake kit that I was able top get a kit with 5 on 5 so that solved my problem and my 56 Panel I used Camaro, changed out A-Arms and run the big GM parts to get that 5 on 5 bolt pattern
12649
Did the same on one of my Corvairs :roll: Those BOP wagon brakes would really shut down that big block, and the factory Riviera wheels added a little class IMO!
