America's Roads going down the drain
6166 Junkyard Dog
Post by 6166 Junkyard Dog »
here's my rant of the week :boxing:
they can send people to the moon, BUT Have not figured out how to build a bridge to meet the highway yet :?: :?: :?:
they can put salt on the road use that pre-salt liquid, I guess they don't care what they put in our lakes/rivers when this xxxx wash's in it :mrgreen:
OK
2 trips ago spit our trailer in half on one side dues to roads, Especially LA. and Miss.,, had to chain binder it with 2 big log chains to get home, now it's plated and welded :x
Next trip broke 2 sets of U-Bolts that we carry extra parts for this
Now went to Boston, Friday night and 3 major construction zones took us 2 1/2 hours to get through on I-81 and I-84, Then over on I-84 in NY hit 2 bad bridges so bad that it broke the exhaust system by the engine so now have to go to Ford and press them hard to fix by tomorrow night, had to listen to that thrashing machine rest of way and back home :( :x
then on the way back somewhere broke a grade 8 chain on the front SUV truck we had on the trailer, glad we stopped at rest area to kick a tire
First thing they say trucks tearing roads, :bs: it's the xxxx they put on the roads in winter, then some of these companies get kickbacks to use cheaper grades of asphalt or concrete
we are having this much trouble, I wonder how the big companies are patching there trucks back, if they even are, and if not putting a lot of lives on the line
12649
LM14
Re: America's Roads going down the drain
Post by LM14 »
I spent 34 years in the road construction and maintenance industry.
First, loads are much heavier than they were in years past. Roads were designed to a lesser load rating than what they now see. That is a fact.
Most states use something as a funding method specifically for roads. Iowa for example, uses gas tax as it's main funding source for roads. Gas tax rates have not kept up with maintenance and construction expenses. Fact.
The Federal Highway Department has their heads so far up their a$$ they they need sunshine piped to them. As an example, we submitted "alternative construction methods" for widening roadways with what is normally considered a waste material. The widening process was basically free. It saved the contractor fuel, time and trucking expense since they didn't need to remove the "waste" material from the jobsite. They simply incorporated it into the widening trench and the road was 2' wider on each side. After the overlay that was a part of the re-construction plan, the widening material was completely hidden. We had done this on non-federal aid roads for several years. The Feds would not accept it, it wasn't a "normal" construction process according to them. The only method they would approve cost an additional $40-60,000 per lane per mile. You must remember that the Federal Highway Department doesn't have a single foot of road to design, build or maintain, they just secure funding for those that do the work. Idiots from one end to the other.
Pre-treatment/de-icing of roads with salt water is the biggest scam in the history of roads. It does help keep snow from sticking to roadways IF PROPERLY APPLIED AT THE PROPER TIME OF A SNOW EVENT. It is not meant to be used as snow removal but a pre-treatment. It's a joke. Everyone operates under the "a little is good than more is better" mentality. It's cheap t produce but actually fairly expensive to apply time after time when everything is added up. It causes half life span on bridges, roadways and ruins equipment and vehicles at an amazing rate. Why is it so popular? Because most states, counties and many cities have adopted a "dry roadway surface" policy. That means they will spend what it takes to get snow off a road as quickly and completely as possible. Know a lawyer? Now you know why they adopted those policies. Todays society wants to be able to drive where they want and when they want at the speed they want, not drive responsibly or wait for the snow to be removed. Society demands it.
We as a road department saw a much reduced life span for trucks. We switched to stainless steel boxes, stainless spreaders on the back of the boxes for the road materials and repaired truck frames as needed. It's crazy.
I know kickbacks have been found in the road industry in years past. Iowa bans contractors and fires anyone involved on the State end of a kickback situation. They are also prosecuted to the maximum amount. It has been done in Iowa. The East Coast is an area that is rampant with mis-spent road funds, bridges that go nowhere, padded contracts and expenses. The main changes lately in road contracting are mostly related to issues on the coasts. There have also been issues in midwest states that have caused rules to be changed drastically in the last 5 years.
This is the reason I retired. You now spend more time getting paperwork done than paving a road. The Feds are completely out of control and are so nasty to the State level officials that most states are now running scared of reduced Federal funding. You cannot imagine the layers of paper upon paper that run this industry these days. It's so bad that in Iowa most engineers at the Iowa Department of Transportation have been replaced with accountants. Accountants, while necessary for some issues, are not known for road construction knowledge.
In Iowa, the cost of a 100' long concrete bridge in 1989 cost around $100,000. That same bridge today will be in the neighborhood of $350,000. That's only construction costs. Iowa has not increased gas taxes since 1989. The money is not there anymore and they are demanding more hoops be jumped thru to spend that lesser amount of money. Wetlands determinations, endangered species, archeological clearances, historical clearances, lead paint, treated lumber, hazardous materials testing, etc. You will now spend more to get a project approved than it cost to build 20 years ago. You easily spend that $100-150,000 before you ever got to design anything! It's totally insane.
Fact.
6166 Junkyard Dog
thanks for that input I know a lot of :bs: goes on that the public is not aware of
12649
