Spindles
Spindles
Hi Guys. I just picked up a 69 f250 camper special parts truck with power steering and disk brakes. My plan is to swap out the steering and 2 speed wiper motor with my 65 f 100. My question is will the spindles work if I would get 5 lug rotors? Are there any other parts I should consider swapping also that are better? Thanks again, I can't tell you how much this site has helped me through the years!
William-in-St George
Re: Spindles
Good score! You will need to harvest the PS pump, brackets and hoses. Hopefully the engine is similar to the one in the 66?. The steering column and brake booster and MC along with the proportioning valve will work. Some of the steel brake lines may be salvaged and used as a pattern. The spindles will not swap so you will need to locate a set of F100 disks and calipers. Pretty much a remove and replace deal. IMHO.
William-in-St. George
Re: Spindles
Thanks will!
Re: Spindles
Anyone have any other suggestions for other parts that I could use off of it, that would be an update to my 65? Thanks again!
Re: Spindles
Does it have sway bars? If it does you can put them on yours. I have a 1974 camper special that im using as a doner. The sway bar it has is the bar between the radius arms.
Re: Spindles
Good call! I will have to check. Thank you!
