"Garage Sale" Find
LM14
"Garage Sale" Find
Post by LM14 »
Every week or so, I get on the Speedway Motors site and check out the "newly listed" items in the garage sale area. Found this Sunday night for $30 off. Sale priced since it was "dirty". Valley cover for a Y-Block. Right around $69, not too bad.
Shadow
Re: "Garage Sale" Find
Post by Shadow »
Nice Score. Speedway Probably Had It On Your Doorstep The Very Next Day, They Ship Faster Than Anybody In The Industry :shock: ...........
bruceandersson
Post by bruceandersson »
I've checked those out not many dress up parts for y-blocks. The question becomes how do you fill the old without the fill tube?
LM14
Post by LM14 »
I plan to do a bit of work on a mill and add a hole for the filler and a second hole for the PVC valve.
I've used these fillers on other things in the past great. Access is a little tight but they are clean looking when it's all done.
http://www.speedwaymotors.com/Weld-or-B ... ,1608.html
For the PCV valve, I use Moroso valve cover gromets that have the baffle built in so you don't get oil everywhere.
Not a simple bolt on but still a good starting point.
slixtyfive
Post by slixtyfive »
I seem to recall you mentioned having a Y-block (or two or three) laying around but i don't recall that you have one in a project/vehicle.... Did i miss something or are you just 'gathering' for future use since we are heading into winter and all...??
LM14
Post by LM14 »
I've had a couple 292's for several years.
One is a good engine, cleaned, new cam bearings, crank turned, '57 T-bird heads and intake, baffled truck pan. The other is a core engine with small valve heads and a billion+ miles on it.
Never know when a guy will need to put a Y-block in something. If there was a better (read that, cheaper) way to put an AOD behind one, I would consider it for an upcoming project I'm trying to get my hands on right now.
slixtyfive
Ah - the '37??
I've been thinking a Y-block might be a good power plant for my F1 that has patiently been waiting for some attention. I might be looking for one in the near future.....
kstones63
Post by kstones63 »
I saw one today at the Good-Guys swap meet. It said that it was for a y-block. It was smooth aluminum and had a filler tube welded on it with a cap. He wanted $20.00 for it.
If anybody is interested, I can text them a pic. I will be out there tomorrow from about 8am until probably about 4pm MST
My cell phone is six zero two, three seven six, seven four six seven.
Kevin
kstones63
63 F100
29 Ford Sedan Delivery
99 F250 PSD, 4x4, CC
95 F350 Flatbed Dually Diesel
