OMC 235 rated 351w cam specs
64 f100
Post by 64 f100 »
Deciding on what cam to use in my grandsons engine and have the one from a OMC 351w. Thinking of using it but have no idea of what the specs are and what fuel mileage it might get with this cam. The engine was rated at 235hp but that tells me absolutely nothing. I will be using the heads off this engine, as these only have the equivalent of 50K miles . Unsure of exact original app. of the heads other than OMC . Still looking for numbers. Otherwise , anyone have any suggestions on where to find info on this cam or suggestions of a good cam for the engine?
Re: OMC 235 rated 351w cam specs
Marine cam specs used to be difficult to obtain from the boat manufacturers, but as installed in the Mastercrafts, the cams seemed very much like those of the truck 351s until 4400 or so, where the power started falling off. Depending upon planned usage, my preference would be a cam with similar specs to the 5.0 B303; of course in a non-roller grind. The heads are probably roughly equivalent to, or the same as, the early truck heads. I would suspect they will not have hardened seats, but do not know for sure, since some were made to run on "white gas". The OMC I have still sitting around is going to end up in Dale's ' 55, and, since he has an 8000 rpm tach, and believes in no wasted gauge numbers, will likely end up rollerized :twisted: , as well as somewhat "enlarged" under Brodix heads.
64 f100
Post by 64 f100 »
Not wanting to get my grandson into any more trouble than he can get to on his own, I'm not going wild on the motor. Trying to get 15mpg out of a 66 short bed. Most likely will end up calling comp cams or one of the others to get some info. The engine was a 74 if I remember right. The block I'm using is A C9OZ, and has been deck trued and bored 30. Hated to go that far over as it didn't need it, but it seems hard to find anything smaller in pistons these days for a reasonable price. Still debating having it balanced, seems overkill for a mild motor. As is, I could have bought a nice used motor for what I have in machine work on this one, and that won't include the heads.
64 f100
Post by 64 f100 »
I also need to ask another question about a set of roller timing chain and gears. I will preface this by saying I bought the innards of a roller 351w block a few years ago. Amount the stuff I got were the timing chain and gears that came from the stock Ford block. All new parts that were installed but never run. what I would like to know about the timing chain and gears is if these are retarded or straight up on the timing? I know that in the70's Ford retarded the timing on their engines to try and meat the governments demand. Did they change this back when the roller cam engines were introduced?
LM14
Post by LM14 »
If it's a stock Ford timing set, it's probably retarded 4*. They did it with the cam gear. Since you are looking into a Comp Cams cam, buy one of their double roller timing sets to go along with it. Since the roller cams have such a different profile from a flat tappet cam, I think they actually changed the cam to use the existing timing sets.
Boat cams are designed to turn a constant RPM in a very narrow band, not what you want on a street engine.
I would suggest a Comp Cams 262H for a mild build. A Cam kit with springs, cam, lifters, timing set is the best way to go pricewise. Cam is a horrible place to try to save any money, it's the heart of the engine. Good place to spend and get exactly what you are looking for.
The C9 block is a low deck (9.480" tall) block. That will gain you some compression. Make sure you have valve clearance when you put it all together. Should be good with a mild cam but never hurts to check in when using the early short deck blocks, especially since yours has been decked.
Good luck!
64 f100
Post by 64 f100 »
Block was not decked per say, just squared up and trued up.
1961 F350
1964 Galaxie convertable
1965 Ranger, and shortbed
1966 long bed, and shortbed
A few parts trucks also
1991 Capri
2011 F250
2004 Lexus
64 f100
Post by 64 f100 »
Just checked comp cams site for a 262H and there is not one listed for that number for a 351w. I just went back and found an EX262H so I will revamp my response. What I found was the kit was listed at 370$ , but then it says screw in studs and guide plates are required. By the time I bought all of that then had the heads redone with hardened seats, etc. etc. , I would have had a fortune in the rebuild of the top end. AS is the bottom end has already cost far to much for the machine work and rebuild parts. Should have gone and bought a good used motor and been done with it or just left it alone until it blew up, and then replaced it.
