interchange/ lowering/ staight axle for a 64 f100
ok got a question, looking at diff ways of lowering my 64 f100. just saw on hamb that the front axle out of a 62 one ton is a direct bolt in and a 3 inch drop. has any one heard of this? also what leaves would you pull off the front to safely lower it?
Re: interchange/ lowering/ staight axle for a 64 f100
My understanding is the 1/2T & 3/4T axles are the same, BUT the spindles & brakes are different on 3/4T.
The 1 ton axle is different than the 1/2T/3/4T, AND uses a larger OD kingpin, so the 1/2T spindles will not work on 1T axle, please post a link to the thread on the HAMB, would love to read how this all works (for real, as I have a '64 M-350)
wasn't a "how to" just part of another post about lowering
Hunter's 64
http://www.droppedaxles.com/
talk to Sid he can answer your questions , or stretch yours to lower
Danny
Danny
- Gary Seymour
If you can find a spring shop in your area - a place that does suspension work on trucks, they might be able to reverse the spring eyes for starters. Then there's de-arching the springs which could limit your suspension travel.
I sent my '62 Uni axle to Sids and he dropped it 3". However, with the tire I have the axle is very close to the ground and I can't even fit a jack under it. Eventually I will have to put a taller tire on. Defeating some of the purpose.........
If I could do it over, I would not drop the axle more than 2", and maybe go with mono-leaf springs.
How low do you want to go?
I Have The Reverse-Eye Mono's On My 64'. They Will Give You 4-1/2" Drop Up Front & 6" Drop In The Rear. Direct Bolt-On, No Tie-Rod Blocks, No C-Notching Or Cutting Of The Bed Was Required....
what companies do mono's f and r for these truck? i live in a small town so "leaf spring shop" that funny
Hunter's 64
https://www.performanceonline.com/1948- ... ION-PARTS/
this is where i got my mono w reverse eye , i bought my brakes from them also.
if you have the funds they will do a package deal i talked to " the old man " the owners father he pretty easy to deal with.
Danny
Danny
