I've found a place to get j-nuts (or cage nuts) in 5/16-18. The originals are 5/16-24. Anyone know where to find the fine thread hardware?
Better yet, anyone know where to get the nuts that pop into the radiator support? They have a sheet metal clip the holds them in the square opening. They are 5/16-24 also.
Front Sheetmetal Fasteners
- Gary Seymour
Re: Front Sheetmetal Fasteners
Forget the pop in nuts. Drill holes in the bottom of the support and install regular nuts, so the next time it comes off you won't be fighting the j-nuts. Besides adding drain holes to the support helps keep the things from rusting through.
1961 F350
1964 Galaxie convertable
1965 Ranger, and shortbed
1966 long bed, and shortbed
A few parts trucks also
1991 Capri
2011 F250
2004 Lexus
1991 Capri
2011 F250
2004 Lexus
i searched thru several fastener books at work, no fine thread bolts or nuts to be found,
Hunter's 64
http://www.amkproducts.com/catalog_pdf/56-73.pdf page #60Gary Seymour wrote:I've found a place to get j-nuts (or cage nuts) in 5/16-18. The originals are 5/16-24. Anyone know where to find the fine thread hardware?
Danny
- Gary Seymour
That's an incredible catalog, Danny. It's even got the pop-in nuts!
The place I've found with the 5/16-18 j-nuts and body bolts are priced at $12 for (25) pieces. So I'll stick with the coarse thread.
Holes from the bottom of the support will work, too.
Hunter's 64
yep they are pretty pricey , i would go the same route with the course thread.
Danny
Danny
Lowe's has the course thread J-nuts. In the hardware section they have a cabinet or two with a lot of automotive stuff. I was surprised when the auto parts store didn't carry them and told me to check at Lowe's.
only an issue for the 61-64s
for 65 ford changed to coarse thread
be careful if you get a 61-64 door from a boneyard, get the bolts too
speaking of which the uni bed bolts are 7\16 fine thread carriage bolts bet i cant find them either
