Pulling a 5.0 out of an 83-91 Grand Marquis/Crown Vic
The Big M
Post by The Big M »
Has anyone ever done this? I'm wondering if I can pull the motor and tranny out together, then disconnect them from each other when the whole works is out of the car. I'd probably have to take the front fascia off the car, but I think that can be done fairly easily.
My reasoning is that it may be easier to access the bellhousing bolts when the motor and tranny are out, rather than struggling to find clearance between the bellhousing and firewall (it's pretty tight in there).
Any thoughts? Is this an easier way to do it, or is it better to unbolt the tranny, pull the motor out, then drop the tranny out the bottom? It's a fuel-injected 5.0 with the dual-sump pan, and the tranny is an AOD.
Ford4jack
Post by Ford4jack »
Never been there or done that on that model car but I bet it was put in as an assembly at the factory.
Might want to put the wheels up on good solid blocks high enough to get good ground clearance if you try to tip it up & out.
One sure way to find out and if it has to be split at least everything is loose and ready to go.
Remember to drain the transmission :lol: that's what I seem to forget about when tipping oil filled things up. :roll:
Phil
Post by Phil »
$4 trans plug has saved me some serious messes.
Id pull it together. I have a 97 5.0/AOD in my garage out of a cougar.
It was pulled together.
Ive never done my 460/C6 in my Torino any other way.
mikecarson
Post by mikecarson »
I did it the hard way, lifted the whole body high enough to roll the engine/tranny out while still attached to the chassis.
Mike C
64 CC, Crown Vic project
62 CC
67short 94 F150, 433W
I have never pulled and engine and tranny separately. I sold a wrecked 87 Crn Vic S I had to a guy who pulled the 351 & AOD together while the car was still at my house.
The Big M
Post by The Big M »
Thanks guys. I took another look last night and I think I'll definitely pull both out together. My teardown manual says that the engine and tranny must be removed separately, but I'm not convinced. The rad is out and I took off the fan, so there's plenty of room in front. And the car is up on jackstands, so there's plenty of room underneath.
HeavyHauler wrote:$4 trans plug has saved me some serious messes.
That sounds like a good idea. I was just going to drain it.
Slick Fan
Post by Slick Fan »
Those little tranny plugs are lifesavers, for sure...as long as you don't bump it with your foot or something. :oops: :lol:
I have yet to remove an engine & tranny together, I guess I'm sort of a masochist. :shock: I should try it next time & see how I like it, I suppose. :)
As far as how the factory did it, with the Crown Vic's being a full frame car, I'm thinkin' they installed them on the rolling chassis & lowered the body on later.
The Big M
Post by The Big M »
Yeah, probably. Now where's my torch? :twisted:
The Big M
Post by The Big M »
I did a quick web search but couldn't find a trans plug anywhere. Where do you guys get them? It's a bit of a moot point now, as I already drained the trans last night, without spilling on the driveway, no less! Hooray for cardboard!
Should I keep fluid in the trans to store it? I won't be putting it in anything for some time, since the 5.0 needs a rebuild.
Also, are the trans crossmembers in these cars useful for anything? I've heard of using the earlier LTD crossmember in our trucks, but are these any different?
Anyway, with any luck the motor and trans will be out of the car tonight. I still need to unbolt the crossmember, disconnect the exhaust, and unplug the wiring harness. Then it's off to the races!
Fanatic
Post by Fanatic »
Back in the day I put a piece of inner tube (remember those) around the end and a hose clamp.
The other option is to have your helper be the DOWN man---while YOU work the hoist!
The Big M
Post by The Big M »
Inner tube, great idea! I wish I would have thought of that. As it turns out I didn't manage to drain all the trans fluid until the motor was tilted up. I also didn't get all the coolant drained out of the block either. Oh well...
I did manage to extract the motor and trans together, without a helper and without unbolting the crossmember. The only problem was the exhaust. I tried to get it out with everything ahead of the y-pipe still connected to the manifolds. It worked out alright, except for the little crossover pipe connecting the driver and passenger side catalytic converters. It didn't survive... :lol:
