Posting pictures of 65 progress on other forum at 7 tonight
64 f100
Post by 64 f100 »
I know, I should go to the trouble to post these here, but it's much easier for me to post the pictures there. Will try to post these at 7 this evening , so those that want to view these can. Pictures to be posted are of clutch rod repairs and repair of clutch rod bell crank and arm holes. Along with pics of the inner fender and radiator support I am installing in my 65. I will try and get pictures of the radiator frame hole repairs also before posting pictures. I am installing a 66 support in the 65 along with a 66 battery box. Hopefully it will turn out well but who knows. Used some older paint from two different cans of rustoleum , and then went over it with some fresh. Took the pictures before it finished drying and I have some areas that now have a wrinkle finish. The three cans of paint did not mix well , or perhaps I loaded it to heavy. I've had this problem a few times before with rustoleum in rattle cans. Anyway I'm not redoing the paint. It has plenty on it and it's protected from rust. To get the right size hole for the frame mount I used 1 1/4 inch washers. I did away with the two cage nuts on the bottom of the support for the two braces going up to the hood latch, by drilling holes in the bottom of the radiator support. This also give more drainage to the support. Going to try and paint the inside of the support with chassis saver at least of the bottom. Looks like mission impossible but we will see if I can do it without making a total mess. Und decided if I'm going to replace the lower bumper filler piece or try and repair the one that came off it. Pretty well damaged in the past. It's solid and I've hammered it back out but it's rough in but getting it perfect is way to much time. May just paint it as is and see how it turns out.
