Fender to Cowl Seal
Gary Seymour
Fender to Cowl Seal
Post by Gary Seymour »
Been so long I forgot where the fender to cowl seal goes. Does it go on right at the rear edge of the fender, or towards the front ahead of the attaching bolts?
Gary Seymour
Re: Fender to Cowl Seal
Right or wrong, I stuck the seal here on the fenderwell side of the mounting bolts. I reasoned it would be better to keep as much crud away from the mounting bolts that way.
rw66f100
Post by rw66f100 »
Farther back in the groove behind the 2 nuts.
Gary Seymour
It made more sense to me to keep crud away from the mounting holes and hardware, so I put them as pictured. I test fit the fenders against the cowl with the seal there and I liked the way it sealed. :dontknow:
