The FEMA gasifier from the Reagan era? You could run an engine on it for a week or so before everything ends up messed up from the tar that'd come from it. I was going to run with an Imbert-style downdraft gassifier wroth a monorator-style hopper.
Then again, I'm still trying to get the brakes working on my truck while you're staying to build the thing.
I've heard bad things about the FEMA gasifier, so be careful with that design.
1966 F-350 verywrongbed
Re: 1966 F-350 verywrongbed
My wife and I are proud owners of:
1997 Ford Taurus GL (his)
1997 Lincoln Mark VIII (hers)
1974 Lincoln Continental
1966 Ford F-350 verywrongbed
Sproino, one trick Kid and I learned about moving trucks with a bad fuel system is to hang a riding lawnmower tank..SECURELY under the hood o move it around before you get the real problem fixed.. might keep you out of trouble with THE LAW !
orangeRcode
foodstick sounds like an authority on avoiding the authorities!foodstick wrote:Sproino, one trick Kid and I learned about moving trucks with a bad fuel system is to hang a riding lawnmower tank..SECURELY under the hood o move it around before you get the real problem fixed.. might keep you out of trouble with THE LAW !
Good luck with your truck Sproino. Looks like you have a long list but have alot accomplished already.
