Picked these loose engines up last week. The 430 will go in one of my slicks. Fordfe.com thread below.
http://www.network54.com/Forum/74182/th ... iew+Thread
1958 332 FE & 1959 Lincoln 430 MEL
Re: 1958 332 FE & 1959 Lincoln 430 MEL
Tried putting a 430MEL in my '62 uni. Wouldn't clear the Industrial Chassis front crossmember and there are no rear sump pans for them. Oil pump basically sits against the bottom of the pan in the front sump and you wouldn't gain any room with a rear sump pan anyway.
They weigh over 1000#, they have a cool factor but are not really practical. Rebuild parts are very expensive and basically no aftermarket support.
A couple years of MEL engines will bolt up to a C6 but most take a dedicated transmission. Again, these are expensive to rebuild and a lot of shops will not do them since some parts are specific to that tranny. The one I had would bolt to a C6 and you can use all the stuff off an FE to convert them to the newer style tranny.
Enjoy,
Enjoy,
Your right about the transmissions. 58-60 share FE, changed 61-63? then again 64?-68. I saw a 430 once that had both the later patterns cast and tapped in the back. It will be expensive if I use it in the F100 as a hot rod. Not so much as stock in the F250. With around $1000 in pistons I still should get under $2500 assembling it myself. I tucked it way back cold. Won't be any where near the back burner for a while.
LM14,
Do you know anything about the LX transmission? From the MEL website thats what the 10 1/2" is called. First automatic cast iron bell housing I have ever seen. The tail housing is the only aluminium part. My 65's are twin I-Beam. Did yours have unused engine mount bosses by the freeze plugs?
The tranny shop I talked to
said it's basically the same as a Cruis-o-matic if I remember correctly.
Saved this from when I was messing with them. Got it on the HAMB.
..........'58-'60 MEL blocks use a std. FE pattern & can use either an automatic or manual.
'61 blocks use a unique to that year bellhousing with the high starter location (FE), but a different trans case pattern.
'62-'65 430s use a modified FE pattern with a different starter location, not compatible with a reg. FE. You would have to physically cut part of the block off & do other machine work to fit the standard FE bell & starter. I don't know what kind of oil galleries, water passages, etc. were relocated to that area, if any. None, from the looks of things. The starter location was dropped for chassis clearance, apparently. Don't know of any one who has tried removing that area of the block. Yet.
The 462 uses a dual pattern...both the modified FE & the weird 462-only, C6 only, "trapezoid" pattern. Apparently there may be some late '67 462 blocks that have ONLY the "trapezoid"...I've not seen one personally & don't know if it's true. Seems unlikely. (Side note..385-series 460 blocks have the trapezoid pattern as well as their own pattern, & did until the D9TE truck block came out. Just a little Ford trivia!)
To make a long story short...the '61 & newer engines have to stay with a MEL-specific transmission...which means, automatic only. For you that would be a CruiseOMatic, for your '64 block. If you had your heart set on a manual, it's '58-'60 383 or 430 blocks only...at least for a "bolt-in" combo without block butchering, & whatever else. The CruiseOMatic isn't a bad trans at all if done right, & not terribly hard to find for a MEL. May cost you though.
Otherwise, you could go with a 462 which as mentioned will accept either the CruiseOMatic or the MEL-specific '66-'67 C6.
For these & other reasons (heads/intake manifolds)...'58-'60 MELs were preferred for swapping.
Your last option that I know of is the Bendtsen adapter. I have heard of some issues with it, & his customer service, but I have no personal experience with the company. Two sides to every story, etc. etc......
Hope that clears it up.
Thanks for posting the correct transmission info. I passed up a 64 MEL for that reason. My friend saw this 1959 430 and bought it for me without asking. No complaints, I just owe him a complete 9" axle. I prefer period correct however the cheaper route maybe to find a 462 and rob the rotating assembly. The lowest unused engine boss by the freeze plug is 3" from the pan rail like the FE pickup mount, only it puts the engine 1/8" forward. I will either find a single bolt/nut engine mount to fit my perch or modify the truck mounts.
tomrooster
Check the rocker arms on the 332 might have adjustable ones , worth some cash. Tom
1966 F 100 w/391 ft
1965 F 100 project
1958 Edsel Pacer Convertible
1953 ford Customline 2 door
1952 8N
1967 triumph Bonneville
1966 F 100 w/391 ft
1965 F 100 project
1952 8N
It's non-adjustable. I have read that some hydrolic cams had adjustable rockers, wonder if they were 4v.tomrooster wrote:Check the rocker arms on the 332 might have adjustable ones , worth some cash. Tom
