OK, It is winter, what is on your to do list
What do you guys and gals have planned for winter projects? I have my 65 in the garage and am needing to get some money in the mail to Tom for some parts he has for me. I want to put AC and PS in it this winter along with pulling the engine and transmission to clean it up and paint the engine bay. I am considering an auto trans but it might have to wait, ( cant make up my mind )!.
What are your plans?
Re: OK, It is winter, what is on youyr to do list
Trying to get my new shop finished so I can get busy on my '66 flareside this winter. Hopefully I'll be driving it to Slick stock.
- skidoorulz
Re: OK, It is winter, what is on your to do list
My to do list. New wheel bearings front and rear Buick. Done! New multifunction switch Buick. Done! New tires on the Dodge. Done! Replace backlight bulbs in radio Buick. Done! Pull battery for storage 64 Ford. Done! Looks like my projects are all done for the winter, I guess I can go snowmobiling for the rest of the winter
With any luck shovel snow.....
Build the engine for the uni, drop the tranny at the guy that is going to build it for me, get the big window section put in, get it all in primer and start making it road worthy for Kansas! Wiring, plumbing and some glass work. Also have to make a gas tank. Then there is...........
Not much on my list,would have to work in the backyard or a cold barn with no electricity.
What is this "winter" of which you speak? Just now got to the point we can use up some of last year's medium reducer!
- jkimbrel65
Got a tilt hood kit to install
Mike
Mike
I tried being normal once...
finish my truck up, i need it
also have some painting to do in the house
whoop some recruit butt for the next 10 weeks.... In that time I will tear down the 223 engine. I whole heartedly intend to do some welding on the bed of my truck too. Been putting it off for far too long.
Monstaliner the bed of my '13 f150 fx4x4 and all kinds of little projects. As always- I will post the useless and annoying shit I always do.
orangeRcode
Pull the engine and fix a major oil leak that I suspect is coming from the rear main. Install aluminum intake, 4 barrel and longtubes. Would like to throw in a new bumpier cam but will have to see what the finances allow. Have disc brake components and new power master cylinder to go in as well. Possibly pick up a 65 parts truck. Alot to do and short time to get there.
- 6166 Junkyard Dog
winter time does not slow us up,, it's just a little messier and colder to deal with
Kathy
Now Cooper will try his best
Planning a front suspension swap from a 78 donor, ps, pdb, and a C6. Also need to do some rust repair on my kick panels and door pillars and swap in some nicer doors.
Might be a 264 day 18 hour sort of thing...
Corey
Corey
1966 F250 LWB
Get the engine put back together and back in. Some exhaust work and
get trans redone. Then some priming and painting. Hood swap too. TR
- ezernut9mm
i need a shop. lol. i guess i will stare at mine for the next three months. i have to install the newly shortened steering shaft, weld up the big hole in the trans hump, cut a new hole in the trans hump, convert my 460 to a rear sump oil pan so i can change the oil, recover the seat, and make sure my second gear band is adjusted properly. other than that, i am good.
Plan is to pull 390 out and have it rebuilt. Leaning towards a Performer RPM top end.
Lou
1965 F100 Short Bed
1965 F100 Short Bed
- ThinLizzy13
Planning on rebuilding a 302 and a C6. The reality is I'll have a 302 and a C6 sitting in my garage for an undetermined amount of time lol.
