Any way to convert to a 3 speed heater motor
66camperspecial
Post by 66camperspecial »
Now that I have the heater working better the present low speed is a little too high so I was wondering if there is a way to convert it to a 3 speed so I can slow that heater motor down a little.
Re: Any way to convert to a 3 speed heater motor
you can get a multi speed switch from a later truck, they are not the same as the slicks but the motor is no different.
the wires just go thru the rheostat so it would be a simple conversion
bump or dentside switch would work
FarmMotorSports
Post by FarmMotorSports »
Does this help?http://rsandas.com/P2_Session_3-3.html
Creative use if junk yard switches and resistors should do the trick..
61 F250 Unibody
& 4WD
FarmMotorSports wrote:Does this help? http://rsandas.com/P2_Session_3-3.html
i think thats a great diagram and will work fine
66camperspecial
Does anyone know if the bronco and econoline vans from the 60s used a similar made switch and have more then a 2 speed blower motor.
pretty sure the 68 trucks were the first ones to have more than 2 speeds
this is when the change from pull switches happened
cars may have them earlier
i may have some old aftermarket heater switches that look similar to the slick type they have the rheostat on the switchi will see if i can find one and get a pic
