I need a camshaft education
Guys-
I dropped the block off at the machine shop yesterday as well as the head, and crank. He looked at the camshaft and said "buy a new one".
So- I need an education on camshafts for a 223. I did a quick google and see that they have hydraulic lifter ones available- but I am not sure which to buy. Can I buy a hydraulic lifter cam for this standard 223 engine?
I found NOS camshaft at what I suspect is reasonable $ so I may go that route.
In my line of work, we NEVER replaced a camshaft... The camshafts are huge and we take stones to the lobes to smooth them out.
Re: I need a camshaft education
Personally, I would have little interest in a "nos" camshaft. Any good replacement camshaft should work well. I am sure there are still "performance" grinds available, but that largely is dependent on your personal preferences. If you go "wilder" on the cam, then other induction and exhaust upgrades become nearly mandatory.
As to changing camshafts; if you have not yet had to change one on a very large mega-horsepower industrial engine, you really should give it a try!
bruceandersson
Post by bruceandersson »
I have always replaced the cam and lifters any time I've rebuilt an engine. Could I have used the old ones? Maybe, but I did not want to have to do the job twice. A hydraulic cam will prevent the need for periodically adjusting the lifters. The most important thing about new cams is to follow the break in procedure and assemble with a lot of lube. Then make sure to either use an additive to your oil or find an oil with the right lube properties for older engines.
The Big M
Post by The Big M »
Interesting, I've never seen a hydraulic cam for the 223. I was only aware of two types of mechanical lifters (conventional and "zero-lash").
I believe Mummert offers a performance grind for the 223, as does Schneider. Here's what Mummert has available: http://www.ford-y-block.com/isix.htm
EDIT: Not sure if you're seen it, but the "Vintage Ford Sixes" section of the Fordsix Performance forum is a good source of information for the 215/223/262. I haven't logged in over there in quite some time but I see there are some fairly recent posts:
http://fordsix.com/viewforum.php?f=18
bird55
Post by bird55 »
Contrary to Toyz comment, There are not a lot of "performance" cams for that engine, AND definitely NO hydraulic lifters. IF you replace the cam it is well advised to replace the solid lifters as well. Make sure you get USA made solid lifters.
Mummert does handle a camshaft that may be a little zippier. But with a 223 IMHO not sure it will be worth the time and effort. As Toyz said it requires more to go with it to get real performance. Again, kind of a minimal cause with a 223. Please don't misunderstand me, the 223 is a good little engine. If it is at a machine shop, you are already putting good money in it, but it won't be cost effective to try and build a Barn Burner :)
Absolutely check with Vern Schumann Parts. He has lifters cams and any replacement part for that engine at the best possible price even with shipping. Schumann Sales and Service. 563-381-2416. 227 W. Mayne St. Blue Grass, IA 52726.
Also consider that with a new solid cam and lifters the engine should be run-in according to specs to make sure the cam and lifters break-in together properly. Mixing used lifters and new cams can make the cam go flat often within a few hours of running.
Good luck and I enjoy seeing your updates.
ok,,, started digging some more and found a part number for Melling camshafts. i assume it is a direct replacement for the original. http://omnitek.co/mellingcatalog/#ag/pa ... 52520Ohv/1
unibody madness
Post by unibody madness »
Clifford performance also has a cam for the 223 with intake/exhaust set up that is pretty pricey.
I have one of their water jacketed intakes If you are looking to upgrade, I collected parts for years and found an intake and exhaust after having bought this intake. I will look up what I paid for it and pass along the savings, P.M. me if you are interested.
Their exhaust headers are high three hundred so keep looking for deals on those, if you look at the Patriot long tube headers, make sure they will fit your truck, they will not fit under the tranny cross member of a 61 flareside.
Ditto to what Big M said great site for Ford I6 owners
The Big M
Post by The Big M »
Here's the Clifford info (it's also a regrind so you'd need to supply a core): http://www.cliffordperformance.net/engi ... print.html
LM14
Post by LM14 »
Unless you want to upgrade the intake, carb, exhaust and ignition, I would just stay with a stock replacement cam. If you change just the cam/lifters and not any of the supporting pieces you won't reap the benefits of the cam. Being totally honest, most cams are probably changed for sound because the driver really doesn't use the cam for what it was intended for. Driving around town really doesn't require more cam. That said, I never put stock cams I anything because that's how I'm wired.
JMO,
I'm building a regular old ford 223.. Nothing souped up on it. Straight across stock.
I was confused at what I was finding for sale because I never deal in cam shafts. I rarely dig into gas engines at that actually. Big gigantic diesels are where I cut my teeth...
The Big M
Post by The Big M »
Gotcha, I was just thinking if you couldn't find a stock replacement perhaps regrinding the original might be an option. My only reasoning there was the listing on Mummert's site stating that the stock replacement is no longer available from Melling. However, it's possible that the passenger car version with the zero-lash rockers is the one that's discontinued. When I search the Melling site for later passenger cars with the 223 it doesn't list a cam, and the one you posted has a note stating "WITHOUT SPRING IN ROCKER ARM, CROSS DRILLED".
"Spring in rocker arm" refers to the zero-lash style, which I don't think was in the trucks or the earlier cars. They look like this:
So as long as you have a truck head on your 223 you should be good. You'll just need drilled cam bearings to take advantage of the improved oiling of the cross-drilled cam.
