Round Speedo Factory Gaugues?
chris401
Post by chris401 »
Pulled this from a plain 66 F100 I6 city truck for $45. Don't know if that's high or not. Are these dealer gauges? If so would they have been in a 65 also?
SLICKCOLLECTOR
Re: Round Speedo Factory Gaugues?
Post by SLICKCOLLECTOR »
same gauges and same bezel in the custom cab dash insert. I have seen this combination several times in non custom cab (round) speedometer.
jim
1966 F100 SW 428CJ C6
1965 F100 SW 428 TL sold
1966 F100 SW CVC 428CJ C6
1965 F100 SW CVC 428CJ C6
1965 F100 SW CVC 460PI C6
1967 F100 SW CVC 521 C6
1967 F350 390 4 SPEED
1970 F350 428 4 SPEED
1974 F350 428 4 SPEED
They could be found in non-custom Cab '65/'66's as well as the older leaf front trucks. You may want to attempt to go back for the harnesses for the gauges and instrument lamps to simplify things. An extra note of caution; if you have upgraded your charging system, I would be wary of that ammeter, and at least would try to get the factory circuit breaker, and, again, underhood harness if available . You will of course, also need the sender for the oil gauge. If you wish to retain the warning lamp, you will need to tee off the oil port for both the old switch and the new sender, as well as run an additional wire from gauge to sender. You will also need to tee off the IVR output to supply the pulsed power to the oil gauge. Factory harnesses make this much easier, but can be replaced with a little patience.
That should about cover it, other than the old caveat that you can never have too many grounds!
chris401
Post by chris401 »
Trucks gone. Part of the wiring harness was cut out already so I left the rest. Would these have been in chrome as well?
Yep
chris401
Post by chris401 »
Was that like mine with oem gauges at one time or did you drill out the holes?
Drilled out the holes for 2 5/8'' gauges. Eyesight not what it used to be, and it wasn't ever great (except when compared with blindness!). It is OEM factory chrome bezel.
chris401
Post by chris401 »
Ok, I had a chrome one without the gauges. I have had this one set aside for a few years. Plan on one day having it refurbished and chromed if chrome with gauges was an option. Going to have this old tachometer refurbished also. Found it in a 60's JC Penny catalog for $11.
To my knowledge, mine is the original factory chrome, although I removed all traces of the black accent paint when polishing (and prefer it that way).
