66 f250 4x4
82f1006cyl
66 f250 4x4
Post by 82f1006cyl »
My name is Clint and I collect 4x4's. I recently found a 66 f250 and bought the truck. I will post a few pics of it. The truck is rough, but it runs excellent, and the brakes have all been replaced already. It was orange from the factory. It has 17 inch wheels, the 352 and factory gauges.
It is the HD version with the 7700 gvw. I think it was a custom cab version also.
f26yr746xxx
wb 120
model f262
body d81
trans a
axle b5k
gvw 7700
hp 172
rpm 4000
dso 720157
I am not as familiar with the mid sixties Ford trucks as I am with other brands. Thats the reason I wanted to join this forum. Lots of great info here on this site.
unibody madness
Re: 66 f250 4x4
Post by unibody madness »
nice project truck
Re: 66 f250 4x4
:welcome: f r o m
K A N S A S
chris401
Re: 66 f250 4x4
Post by chris401 »
Like those wheels, are they one piece? Curious if your truck used the big C4TE bellhousing with engine mount ears and cast iron timing cover.
82f1006cyl
Re: 66 f250 4x4
Thanks for the replies guys.
The wheels are firestone one piece, but they are not tubeless rims. I think they were an optional size for these trucks.
I am pretty sure the timing cover is cast iron. I have a pic I took the other day showing the alternator. It shows part of the cover I think. I am not sure on the bellhousing. I can check for you tomorrow.
chris401
Re: 66 f250 4x4
Post by chris401 »
It looks like you have rubber mounts on sides of block. If it uses them the timing cover is probably aluminium and used a regular bell housing and tail transmission mount. That is the first alternator like that I have seen on a pickup this side of a 1 ton with a man lift. Common on heavy duty trucks / vans and equipment. The bracket style looks like it came that way.
Re: 66 f250 4x4
That alternator was an option regardless of series, probably ordered along with the buyer's choice of orange paint. I may be just missing them, but I do not see a side mount setup. The truck shows to be a Custom Cab; with the listed option choices, my first guess would be that a utility, forestry government, etc., may have been original purchaser. Unusual part to me is that even though it was produced in the first month of production, it has a higher special order number than what I would expect. If it were in fact a fleet order, and with the orange paint, high GVW and heavy duty equipment,I would expect it was; it may well have been a standing order which did not get filled until the advent of the '66's. At any rate, without knowing the final serial digits, it is safe to say it would have been one of first '66 F250 4x4's produced at the San Jose plant.
Good luck with it; it should make a nice one!
chris401
My Mistake
Post by chris401 »
Paul,
You didn't miss it, its not even there. On my phone the alternator block boss looked like the top of a rubber mount to me and the front mount is hidden. My mistake. Was there a name for that particular charging system and is it higher amp or for two batteries?
82f1006cyl
Re: 66 f250 4x4
Yall are correct. It does have the front center mount for the engine.
The alternator is larger than what I expected. I meant to mention that in the previous pic, but I didn't think about it.
The truck does have some unusual options. As soon as I have a chance I will do a title history search and see if I can find out any info from previous owners.
In the next post I will post some pics of the front cover and the bell housing for you.
jamesdfo
Re: 66 f250 4x4
Post by jamesdfo »
Paul: DSO # 720157 would make it the 157th Special Order, what makes you think that is an extraordinarily high number?
James
Toyz wrote:The truck shows to be a Custom Cab; with the listed option choices, my first guess would be that a utility, forestry government, etc., may have been original purchaser. Unusual part to me is that even though it was produced in the first month of production, it has a higher special order number than what I would expect. If it were in fact a fleet order, and with the orange paint, high GVW and heavy duty equipment,I would expect it was; it may well have been a standing order which did not get filled until the advent of the '66's. At any rate, without knowing the final serial digits, it is safe to say it would have been one of first '66 F250 4x4's produced at the San Jose plant.
82f1006cyl
Re: 66 f250 4x4
Here is the sequence number: 7468XX. That should help narrow down the build date.
I have two pics of the bellhousing area of the truck. One pic is of the front cover. It is definitely cast iron.
Re: 66 f250 4x4
jamesdfo wrote:Paul: DSO # 720157 would make it the 157th Special Order, what makes you think that is an extraordinarily high number?
James
Higher than what I ordinarily would expect out of the first 900 total '66 trucks produced, since the tendency was to get the new models in the dealerships before special orders were processed. Two factors come into play here. It could have been as I surmised that the fleet order (if actually such, and it could have been one purchase order for all of the first 157 DSO vehicles), was first entered in '65 production time frame, and continued as the '66 production quickly started. The other factor is that I found '66 production to generally to be started in September'66 with 760000, making it one of the first 900 produced of all series. In fact, possibly supporting the carry-over P.O. thought; with the somewhat minor changes from '65's to '66's, several truck plants were ready and in '66 production in August with serial numbers actually starting at 732000, making that DSO a little more reasonable.
Re: 66 f250 4x4
chris401 wrote:Paul,
Chris, the alternator is a Leece-Neville. There were two versions available on the '66's; a 60 amp and a 105 amp. With the dual belt drive, I would hazard a guess that this is the 105 amp version. Their claim to fame in the early days of alternator usage was their high output (for those times) especially at lower rpm.
chris401
Re: 66 f250 4x4
Post by chris401 »
82f1006cyl
Re: 66 f250 4x4
I think those larger Leece Neville alternators were used on Ford police cars of the same era. I found a 64 galaxie poice car that I have been trying to buy a for a few years but the guy wont sell. That particular car has a leece neville alternator and regulator on it.
jeepbut
Re: 66 f250 4x4
Post by jeepbut »
Are the wheels by chance 17.5. I have never seen a one piece 17 inch wheel. 17.5s were common on government vehicles during the 1960s.
82f1006cyl
Re: 66 f250 4x4
The wheels are 17 inch. They are not tubeless rims though. I guess the 17.5 would have been a tubeless rim? I have a 56 gmc 3/4 ton 4x4 that I am restoring. It has 19.5's and they are a tubeless style rim. I put an old bias ply mud tire with tubes on it though because I wanted the vintage skinny look, and 19.5's are very difficult to find now.
Coker has an original looking 17 inch tire in their catalog. That is what I am going to get for this truck.
tomsrod
Re: 66 f250 4x4
Post by tomsrod »
Nice project. I wish I had room to do another. I'm going to tall skinny tires in the spring, probably 235/85r16. The 4x4s did have a single motor mount on the front center cross member and two motor mounts on the rear. Keep us updated.
Pat
