A couple 292 ??'s
Mr. Jones
A couple 292 ??'s
Post by Mr. Jones »
Greetings all,
Thanks to everyone for the compliments on my 62 350....I'm wanting to get the 292 cleaned up and painted,don't know what color Ford used on their Y-Blocks.Pictures would help.Also did these engines use a double-belt water pump pulley?If so,anyone have one they'd part with?
skidoorulz
Re: A couple 292 ??'s
Post by skidoorulz »
Is it safe to assume this is going into a Slick? If so the entire engine was painted black and the valve covers were painted Ford red. As far as the pulley's my 64 had a single belt that ran the water pump and generator. Don't think power steering was an option and air was an aftermarket so I believe it would have a single belt.
Shadow
Post by Shadow »
Mr. Jones
Post by Mr. Jones »
Dana,
Thanks for the pic.I was thinking the Y-blocks were an off red.....
unibody madness
Post by unibody madness »
I have seen them:
black with ford red covers,
black with gold covers,
and red with black covers.
Just to be different mine is new ford gray with ford red covers.
62bigwindow
Post by 62bigwindow »
I pulled one out of a 61 F600 that was green. It looked to be original but after 50 years who is to say?
64 f100
Post by 64 f100 »
Power steering was an option. I believe Harris made it for Ford and it was still manufactured by them as a kit not to long ago. If, you want more pulleys long on the older larger Ford trucks . I know there were several options , but you have to buy a 2 or 3 shiv harmonic balancer as a general rule. Other things people may not know about the yblock, are that roller chain and gears were on the heavy duty 292 engines starting I believe in 56 as it was a B6 part number. One set on Evilbay at a bid price of 100$ . At least I think it was on Evilbay, may be on St. Louis craigslist. I've been all over the internet lately. Some pieces are available from different parts vendors also. I keep a NOS set on hand for my own engine and have a partial set also.
1961 F350
1964 Galaxie convertable
1965 Ranger, and shortbed
1966 long bed, and shortbed
A few parts trucks also
1991 Capri
2011 F250
2004 Lexus
unibody madness
Dennis Carpenter sells the harmonic dual at a reasonable price.
