cargo light switch
cargo light switch
broke mine the wires pulled out of the ends inside
only replacement i found by typing the number on it (signal-stat) into the search is this one
http://www.ryderfleetproducts.com/signa ... -p-w71-102
lmc dont have them and not sure if i can resolder wires or not
dont really want to spend $30 for another so if anyone has a spare or knows another source speak up
Re: cargo light switch
What about using a toggle switch Brian? TR
Truckrat wrote:What about using a toggle switch Brian? TR
well i already wired up a push pull but would rather have an original type with the light in the knob
might go post in fordification as its really a bumpside part
dont really need the light part but i would buy the whole thing if needed
the one i posted in the link is the direct factory replacement by the same original manufacturer, and the factory cargo light knob threads on
I'm not so sure that switch was a Ford only....
I've seen them in 60s chebby trucks (bigger models) also
CHICOF100
Post by CHICOF100 »
ICEMAN6166 wrote:broke mine the wires pulled out of the ends inside
Send me a P.M. I have one. I also contacted Nasty on Fordification. I have two one for each of you.
chris401
Post by chris401 »
Did those originally go in the dash blank or under the dash?
pretty sure they were below the instrument panel to the left of the steering column in the bumpsides
mine is in the instrument panel below the "blink marker light" button because i did not have any room in that spot
i used a "prime carb" momentary on switch for my windshield washer pump in that spot came from a big slick
chris401
Post by chris401 »
ICEMAN6166 wrote:pretty sure they were below the instrument panel to the left of the steering column in the bumpsides
Thanks. I had a 65 parts truck that had one on a chrome bracket under the ignition switch next to the parking brake. It looked out of place. The one from Ryder looks good.
If correct would the extras have started next to the column and moved outward?
chris401
Post by chris401 »
If a truck came with emergency flashers and a cargo switch: Would the correct or typical cargo light switch location be next to steering column on left?
chris401 wrote:If a truck came with emergency flashers and a cargo switch: Would the correct or typical cargo light switch location be next to steering column on left?
67-72s had the flasher switch in the glovebox
66s with the round speedometer had the flasher in the right side of the panel
heres a 66 custom cab flasher to the right, light then knob
chris401
Post by chris401 »
