I've also purchased a 67 galaxie 4drum non-power master cylinder that I was hoping to use. What do you guys think? Am I setting myself up for problems?
Nic
It was the 1961 manual I was looking at. The adjustable anchor looks like a hex bolt on the backside of the backing plate. The anchor can be moved up and down in a slot. I looked at my backing plates today and they don't have the adjustable anchor anyway, I can't see any difference so I am going to give the double cylinder a shot. If it doesn't work for some reason I will let you guys know.Toyz wrote:I don't have anything except '61 and '62 manual here; I see no adjustable anchor pin, nor have I encountered one to my limited memory.
I looked at those the bore size is listed as 1 1/8 the manual says my truck should have 1 1/16 front and 7/8" in the back.Mr. Jones wrote:Nic,
Don't know if you have O'Reilly auto parts up there,here are the two part #'s that are on my receipt for the single wheel cylinders
Wc36075
Wc36074
Bought these back in 08 for my 350 they looked just like yours.
Hope this helps...
