I went and picked up my transmission from the transmission shop. He said it was in perfect condition and there was nothing he needed to do to it.
I got home, and I was cleaning it so i can get the years of gunk off it and looked inside to see the speedo gear... is it supposed to be worn down like this? When I bought the truck, I noticed the speed/mileage never registered on the gauge.
I should say he said he wouldn't charge me anything cause he had it over a month... I completely forgot about this... Is it something I can take care of myself or should I bring it back with a new internal gear? Would I need new bearing? Now that I got it back, I sort of don't want to lose sight of it again. for a whole month with no contact back from him- I am nervous of dropping it off again.
'63 F100 Custom Cab 223inline 6, 3speed manual- mostly stock https://www.youtube.com/coastiereid
April, you should take it back and at least have him look at it. He didn't charge you when you picked it up so I'm assuming he's standing by his reputation. Just make sure you let him know, if work needs to be done, you're on a tight schedule. Since you're trying to get as much done as possible before you go to your next duty station you're not stretching the truth. I wish I was more of a mechanic so I could look at some thing like that gear and be able to tell the difference between good and bad like some of the folks on this site.
Or, check if there is a speedometer shop in your area. They should have parts in stock.
They should be able to replace the gear, check your cable on a carry in and out basis.
Plus you will know who and where to go when you need adjustments for accuracy.
61 F250 Unibody
& 4WD
April, not sure what transmission you have, but it is certainly something you can replace yourself if it is a removable drive gear on the shaft. I can't tell from the pic if yours is the removable one. I also can't ascertain any damage; they have a little contour to them; but I would expect it would be a good time to replace both drive and driven gears. They were originally color coded, but you will need to count the teeth on each to get the correct replacement, assuming original rear gearing and tire height. Also check your cable for free turning in both directions; any bind, drag, or doubt; I would recommend replacement. A factory manual is an excellent tool for diagnosis and replacement procedures.
Couldn't sleep and diesel had to chase the rabbits so I went out to the garage after watching a few YouTube videos...
The gear isn't in a sealed ft Knox area. You remove 5 bolts and pull the shaft cover off. I have a 6tooth greenish colored gear on there. There is an oil seal on that shaft cover I will replace as well. Should be an easy fix. I will post some pictures after I get it done. Just in case anyone else had this issue. Seems easy enough now I have removed the shaft cover.
I was seeing all these pictures of the transmission without that cover so I figured it was just there to help cover the shaft to attach to the drive shaft.
You are intrepid! I was going to reply to just take the back of the case off to inspect. I do not think it looks right. The tailshaft should have a helical steel gear that turns the plastic gear on the speedometer cable. This gear is about 1/2" along its cylindrical surface. Its been a while since I tore into one of these. But that's what I recall. I do have a similar transmission sitting in my workshop. Let me know if you need pics. I can pull the tailshaft housing off and take a pic of one that is 100% and working when pulled.
Here are some more pictures. I found a replacement part on evil-bay for a few dollars. Turns out it was the same online seller that sold the previous owner the speedo cable gear (17tooth green). I have that in one of the photos for reference.
So- next up I am looking for a part number of some sort for the oil seal at the end of the tailshaft cover. See pictures.
This is the gear itself. It is 6 tooth and obviously looking at it now you can see it is worn! DOTZ 17285 A is what I came up with on the other site.
This is with the new 17tooth speedo cable gear next to the 6tooth.
This is the oil seal i am in search of. Part of the number is 7052. Just need to find the rest of it. I think I can get it at NAPA.
April,
That gear should be an easy swap. The only real problem is if you do not have the proper snap ring pliers that one will be stubborn I finally found an opposing set with flat jaw spade and that's the way to go.
I am not sure the guy did you a service as much as just got you out of the way. These transmissions are grenade proof, so you should be able to spot any real problem easily . I also agree on the shop manual at least the one one cd, and keep an eye out for a cheap printed one on ebay. I would get a half gallon of diesel fuel, pour it in and spin the shaft while going thru all the gears, that will clean it out so you can see. After draining, coat the entire working assembly with an atf bath, spin, and drain that should clean it up nicely. I can send you the sections you need send me a P.M.
At your rate of progress, you are probably beyond this and already aware of it, but the drive gear is secured by a ball seated in the shaft. It WILL take off to help diesel chase rabbits if given the chance! At least you are working with trans removed; making it a little easier to keep parts within range!
Ive been pushing the boot campers through their indoc week (every week I do this) so my schedule is a bit weird. I haven't had the time to get in the garage to take the Drive gear off. I did buy one, and waiting for it to show up in the mail before I take the old one off. I have a tendency to get side tracked easy sometimes and I don't want to take it apart and then realize 4 months from now i forgot where I put the snap ring.
Anyway- I did some searching online and through my parts book and just really never found a direct replacement to be identical to the oil seal. I went to NAPA and this is what we came up with. It's identical in OD and ID. Just the protrusion on one end is different.
The one that I pulled out of the housing is an original ford part.
Any input welcome!
Again, shouldn't be a problem; the dust seal is just moved outward. Just be certain the matching yoke surface is smooth to avoid tearing up the seal.
