18x10 wheel fitment
RRTEC
18x10 wheel fitment
Post by RRTEC »
Ok,
I got a killer deal on some wheels. I wanted wider wheels in the back anyway.. I bought 6 wheels 4 18x10 with 45mm , two 18x10 30mm. I am running 1.5 inch adapters/spacers and currently have 18x8.5 inch wheels with 45mm offset and they fit fine.
If possible I want to run 18x10 on all four corners... Anyone doing that? I'm on stock suspension so you IFS guys.. You don't count..
The 30mm offset fit the rears according to my tape measure (haven't checked the 45mm but I think they would rub.) There looks like tons of room up front.
My truck is a 1965 2wd
Re: 18x10 wheel fitment
If your 18 x 8.5 have better than 3/4" clearance to the outside, the only factor will be tire size. The move to the 30mm offset, (assuming +30!), should put the inside part of the wheel in about the same position, while the 45 mm would move it in just over a half inch. Sounds pretty tight, both front and rear. Biggest problem on the front is usually the spindle/ tie rod clearance; the 18s may negate that issue.
RRTEC
Post by RRTEC »
They are + 45 correct
HotRodMatt
Post by HotRodMatt »
type your specs in to willtheyfit.com
RRTEC
Post by RRTEC »
Well I took some time to test fit them sans tires. Up front I have room for days! Out back they fit but I may have issues if heavily loaded when lowered.
I was wrong my current wheels are +50 and they fit... They are 8.5 wide though..
Back is tight to the outside?
RRTEC
Post by RRTEC »
It's actually tight to the inside I am wondering if I am going to have to do a small "tub" to gain clearance.
Did you try the +30s on the rear?. They will probably move the wheel out too far, but might be worth a try. a 1/2 " spacer might also prove a valuable aid for test fitting your wheels.
RRTEC
Post by RRTEC »
I did, the 30's came out a bit too far. I've decided to run +24 9" up front and the 10" + 45 in the rear with a little massaging.
I'll make a note of that! What size tires?
Thanks,
