Alright so after months debating and doing research and reading everyone's write ups and opinions I've decided to get started on the CV front end swap. I've been so wrapped up in getting all the little things I need for the swap and all the while trying to decide what motor I want to put back into it. I'm in no hurry for any of this just want to take my time and do it right. With that being said and having a pile of parts ready to go in. I started to make a plan for the rest of the truck just to have a goal.
That brings me to my delima. When I bought my truck about a month and half ago I was told by the seller a list of things this truck had. Almost all have been incorrect. I should have known when he claimed it had a 351c and after looking at it for 15 seconds I discovered it was a 351/400m and what he thought was a fmx was in fact a c6. Both of these weren't an issue knowing I was going to change it up anyways. But it came time for him to explain as best he could the situation with the rear end. He claimed engine and tranny where from a Torino. That I don't doubt. But he told me he thinks the rear is a limited slip So I finally decided to jack up the rear and give it the "open rear diff" test and sure enough the wheels spin opposite. So after reading past posts from lots of smart guys on this site I have some questions about rear ends
So from what I've collected the 03+ cv rear won't work because it's to wide? The explorer rear housing needs to be shortened like 6 inches? And the 93ish CV rear end width is a hair short from the front but guys make it work by running bigger offset? So many options and I guess it's personal preference. In the end is any of that really worth it? All I really want is posi trac I mean rear disks would be nice and I do plan to lower it to go with the cv front. As of right now I was just planning to convert to posi trac and lower it with an axle flip. Am I making a mistake? Would love to hear from some experienced members thanks guys
Rear end options
bruceandersson
Re: Rear end options
Easiest would be a new center chunk for your 9". That way you could also get the ration you might prefer. The F100 camper specials came with a limited slip dana rear end, but these would be hard to locate. Note that the lug patter would not match your front.
RustNdust65
Yea I imagine that wouldn't be easy to find. I've checked most salvage yards within a 100 miles from me (STL, MO) and can't find anything 61-66. Now I've heard the 80 f100 rear axle will also work?
- charliemccraney
Re rear axles, up to, I think, '72 is about the same width. The shock mounts are in the wrong spot for '61-'64 but that doesn't really matter a whole lot because with an axle flip, you will have to relocate the shocks to get the geometry back to something good. '68 up gets you wider rear drums which should compliment the CV discs better than the stock rear drums.
Lawrenceville, Ga
1961 F100 Unibody
1961 F100 Unibody
From the research I did the 73 up 9" diffs are very close to the width of the 03 CV front end. My plan was to redrill the rear axles and drums.
Nic
Nic
9" ford 77F150. 65 7/16 wheel mounting surface of drum to the other wheel mount surface
From net: 05 CV. Hub to hub 67 1/2
Track width 63 1/2
Outside of tire 71 1/4
Speedway wheel adapter 5 on 5.5 to 5 on 4.5 are 1.25" thick
Track width 63 1/2
RustNdust65
Is the 03+ CV rear to wide? I've heard many people say it was to wide then a few say no it works but it's tight fit.
Thanks for the measurements by the way the amount of different posts I read through was making my head spin.
Going to be pretty tight with a 4" wider rear end width. Net information translates loosely to +52 offset. That would likely put the tire against the inner fender well. CV is quoted as having anywhere from +38 to +50 offset. Most CV I have seen were +38 to +42. The original CV wheels; or something with +38 offset and the rear spacers, any more (or less), or a wide tire will likely be problematic.mercuryv8 wrote:9" ford 77F150. 65 7/16 wheel mounting surface of drum to the other wheel mount surface
Track width 63 1/2
