Looking for carb base gaskets for my 3x2 setup. I have the paper ones on there now, but they stuck and ripped and need to be replaced. Nowhere around here stocks gaskets for these Holley 2BBL carbs with the dual holes that match the carb & manifold. They have ones with one big oval hole, but not sure if I should use these when the intake has dual holes. Any difference?
Thanx in advance.
Carb gaskets different
slickstysix
1966 SB, 2WD, 390FE, 3x2 6V carbs and intake, 3 on-the-tree (for now).
- Power brakes
- Pertronix electronic ignition
- Ron Francis wiring throughout
- DJM drop beams
- Halibrand Sprint 17x8 wheels
- Power brakes
- DJM drop beams
Re: Carb gaskets different
Check with Speedway, they have a lot of that stuff! TR
- jkimbrel65
carlsfordparts.com
for all your 3x2 needs
Mike
Mike
I tried being normal once...
