brake booster
therealjoeshmoe
brake booster
Post by therealjoeshmoe »
im putting disc brakes on the front of my 65
is this the booster setup i need?
i looked it up for a 72 f100
its the booster and master cylinder
its a a1-cardone #503515
http://www.rockauto.com/info/1/503515-RIT__ra_t.jpg
Image Image Image Image
rbeck204
Re: brake booster
Post by rbeck204 »
I can't tell from the Rock Auto listing, but be sure the booster you buy is for the correct front brakes. In other words, they make disc/drum boosters and drum/drum boosters. A drum/drum booster used for applications with disc front and drum rear will not work. The drum booster has lower PSI output.
Ask me how I know.
61 T Bird Convertible
1953 Ford Customline 2 door
