My dad has a 56 victoria with a 272 engine. This engine was rebuilt about 6 months ago. The engine runs hot. He has installed a new water pump, thermostat, and sender. He also had radiator flow tested. The guage tests good as per the manual.
It actually runs hotter after he replaced all these parts.
Any other ideas.
Thanks,
Wes
overheating
ghostflamed66
overheating
64 4x4 with tilt front end
65 f100
66 f100
66 ranger
66 fairlane 500
65 f100
66 f100
66 ranger
66 fairlane 500
fmartin_gila
Does it run hot the whole time you're driving it, or does it seem to heat up sporadically, for no reason? If for no reason, it could be a head gasket on backwards...been there, done that.
Other things to check...
Make sure the thermostat isn't upside down
Make sure it's even working, while you check for upside down (boil it)
Ignition timing too far advanced
Carb running lean (possible vacuum leak)
That's about all that comes to mind at the moment. Good luck.
- dotcentral
