Here's my cleaned up (sorta) dentside engine.
Slick Fan
Post by Slick Fan »
Let's just say that I definitely don't posses the same gift of 'in vehicle engine detailing' that HH does. :lol:
I'm gonna do a little more as time allows, so this is as far as I am now.
Before (check out someone's idea of fuel line routing :lol: );
This "fix" was some PO's idea of cleaning up some bad wiring, I guess. The truck has dual batteries originally & I'm assuming this was to take out the wiring leading to the other battery? :dontknow: I have no idea.
That's a bicycle inner tube over the wiring that held together with wire nuts. s_crazy5.gif
As I started unbolting things & moving wires, this alternator wire suddenly sparked & started smoking, with a mini grease fire! :shock: It had rubbed on the edge of the valve cover & chose right then to ground out...I'm so lucky it didn't happen on the road one day, it could have turned into a big fireball. :?
Needless to say, the positive battery cable was the next thing disconnected. :lol:
I took it down this far, then started cleaning stuff.
Just so ya know HH, at this point, I came this close > < to saying 'screw it' & yanking the engine! :lol:
About 9 days later, I had to have my truck back together to use it, so I stayed up until 1am last Wednesday to get 'er done. I needed more time to fix things properly, but what do ya do? :dontknow:
(Same fuel line, just straightened, then re-bent with a bender)
The valve covers are dented, with rust pits under that paint. I plan on replacing them in the future. I also plan on getting an air filter that actually fits the full area of the air cleaner, after this one get's dirty enough. :lol:
It's raining today, that's why some spots look wet.
It doesn't look half as good as I had planned, but it's better than it was. I didn't get to the wiring in the inner tube & only patched the alternator wire for the time being.
I'm gonna fix it right, real soon & clean up more of the surrounding area. Gonna paint the radiator top, clean up the plug wires & replace the vacuum advance on the distributor. Next summer, I'll probably yank the engine to do a clutch...it chatters because of a leaky rear main. Then I'll seal up the leaky bottom end & detail it underneath.
Two things that struck me funny & made me consider myself lucky while I was doing this were;
. The alternator wire thing.
. When I moved the p/s pump off it's brackets, the return line popped off it's nipple all by itself & started draining fluid! :lol:
I've been driving this truck for a few months now & it's been just fine...as long as I didn't actually MOVE anything under the hood!
:rotflmao:
dotcentral
Post by dotcentral »
Slick Fan, looks a lot better already. I know the feeling about pulling the engine to have an easier go at it.
I've started on mine last Saturday. I degreased & sanded an inner fender and the core support where I could reach it. Painted the core support but need to do more to the inner fender before painting it. Also sanded & painted the air cleaner assembly. I have to work this weekend, plus it's hot, so I'll try to get back on it next week.
I use Rustoleum rusty metal satin black for the inner fenders & all other black metal surfaces. I also use those foam-backed sanding blocks.
Do you have any tricks for making it easier? Post some more photos when you get some more done, it will help get me motivated to do more?
ABA
Post by ABA »
Wow, looks good. :D
What's that red color around the rockers?
'01 F150 Lightning
490RWHP
Gas Mileage? What's that?
Jerry
Slick Fan
Post by Slick Fan »
Thanks, guys. :D
Dotcentral, borrowing one of Heavy Hauler's tips, I dug out my drill-type wire wheels. I haven't used them in years, but for getting rust & dirt out of crevices on the engine, they work great! The one on the left works great for tight spots & the other one is good for flatter, open areas. :thumright:
I used a couple hand held wire brushes & some sandpaper, but it was mostly the wire wheels I used.
I stuffed rags in the open holes & t-shirts along the open head areas, to keep the crap out. I vacuumed it off 7 or 8 times during the process, to keep the area clean & not let dirt get into anywhere it shouldn't be. Then I doused a rag with paint thinner & wiped everything down well before I painted. Just laid a couple coats on straight, no primer.
Sorry for the blurry pic, my camera didn't want to focus...it has moods. :?
Aba, the engine looks like it's been rebuilt sometime in it's past...or for sure a valve job done. The red stuff is some sorta paint or coating done inside the heads. I've seen a coating race engine builders have used inside their engines, but this sure ain't a racing engine. :lol:
ezernut9mm
Sweden
Post by ezernut9mm »
looks 100% better for sure!
Max
Post by Max »
Yup, nice work for the time you put into it for sure!
Phil
Post by Phil »
WOW looks killer!!!
Nice job. Careful, its a slippery slope.
Next you will be doing the firewall and inner fenders :lol:
I like pulling up in a beater to a show and popping the hood to reveal
a nice engine compartment :D
Phil
Post by Phil »
Try teh Rustoleum #7777 semi gloss black
Its tough and way better than the Krylon.
Its a very close match to the OEM Ford semigloss
It does take 24+ hrs to dry though
66 POJ
Post by 66 POJ »
That thing should have never vapor locked!
1966 F-100 LB
1966 F-250 LB
2003 F-150 ex-cab 4x4
2003 Explorer EB
2004 Mach 1
Frank
shawns fords
Post by shawns fords »
looks great! cleaning an engine compartment can be a long tedious job, when I started on mine, I stumbled across this engine degreaser from one of them dollar stores. I figured what the heck, took two bottles home and started spraying away and the grime just started to have an allergic reaction to the firewall, it looked good like a new engine comp, almost decided to stay with that original bright green or teal color. but just couldnt do that
anyways the store doesnt sell the cleaner anymore :( it was LAs totally awesome cleaner Degreaser for automotive, hopefully ill find some of it again one day
Slick Fan
Post by Slick Fan »
66 POJ wrote:That thing should have never vapor locked!
:iagree: :lol: I assume that's probably why it was done like that. Good function, but looked like hell.
Shawn, did your engine cleaner smell like kerosene? I've got some no-name stuff that smells & feels like kerosene, melts the grease quite nicely, too. :thumright:
I already want to! :P But I'm gonna save myself the anguish & just do it nest summer, when I yank the engine to do the clutch...my masochism only goes so far. neener.gif
Speaking of clean engine bays in ratty cars, have you seen underhood shots of the JOE DIRT car? You'll appreciate that one, I bet. :lol:
