It's the Simple Things that Mean So Much, like .....
ABA
Post by ABA »
having a working windshield washer. :D
Just got mine piped in thanks to some tubing donated by my employer :wink: :wink: and it works.
The new hood I just installed had the squirters on it and I had kept the washer tank from my '69. Just had to install a toggle off (on) switch beside the wiper switch. 8)
'01 F150 Lightning
490RWHP
Gas Mileage? What's that?
Jerry
dotcentral
Post by dotcentral »
ABA, You are right about the simple things. Makes them just a little more enjoyable to drive.
Phil
Post by Phil »
I just redid my alignment on my fairlane. The last shop completely ripped me off. I had all new stuff and was about to get a new $400 steering box when my buddy pointed out my tire wear. I hadn't noticed it.
$50 and now I have the best handling mid-size I've ever owned.
I can actually take huge sweeping banked turns on the highway at 75mph without wondering which guardrail I will hit
Ford4jack
Post by Ford4jack »
ABA
Just wondering if you ever thought about installing a 2 speed wiper setup in your truck.
That way you have the washer function in the wiper switch.
I snagged a wiper motor, harness, switch assembly from a 73 model truck to use on my 66
The motor bolted right up to the old mounting bracket & wiper linkage on my truck.
Had to cut about a quarter inch off the switch shaft so the knob location looked right and run the power wire to the new switch and it was good to go.
Anyway I have 2 speed wipers now and its plumbed in electrically for a washer setup.
Just have to get around to getting the tank/pump motor assembly someday.
I ran across a article somewhere about installing an intermittent wiper setup on slicks.
That might be a cool thing to have someday.
ABA
Post by ABA »
No ford4jack, haven't really thought abouit it.
I am going to put a NOS sticker above my toggle though. 8) :lol:
What's the hold up on getting a tank and pump assembly?
I could have had ya 4 or 5 of the them other day.
I got a spare pump off of one and a wire plug off another one while in the salvage yard.
'01 F150 Lightning
490RWHP
Jerry
Ford4jack
Post by Ford4jack »
Just haven't got around to it.
Need to make a boneyard run soon though. Our little D 50 gas gauge quit working and I cant just look in the tank on that one.
Would just keep it full but I epoxied over some pin holes in the fuel tank a few years back and Im afraid it would rupture with the weight a full tank.
Guess I need to fix that one of these days. :lol:
Slick Fan
Post by Slick Fan »
I think another thing that goes with this subject is functioning turn signal cancellors. :shock: It really sux when you have to remember to turn off your turn signal...before 4 miles have passed. :lol:
Congrats on your windshield washer, that definitely sucks when it's not there. :D
ABA
Post by ABA »
Slick Fan wrote:I think another thing that goes with this subject is functioning turn signal cancellors. :shock: It really sux when you have to remember to turn off your turn signal...before 4 miles have passed. :lol:
I here ya on the signal cancellors, yes mine don't work but atleast I can here the flasher ticking in this truck. :lol:
'01 F150 Lightning
490RWHP
Jerry
ras4434
Post by ras4434 »
WHAT........the turn signls are supposed to cancel. I have owned 5 and none of them have worked properly. My current 65 has a left turn that cancels but the right turn does not.......try remembering that. Actually I am so used to just turning them off after a turn that it was probably two weeks after getting the 65 that I figured out that at least one side worked. The sad part is that I have an assembly in the garage that works but am too scared to tear into this part of the truck, for fear that I will really mess something up. One day I will take the plunge.......I hope.
66fordtrucknut
Post by 66fordtrucknut »
I've had 4 trucks and not 1 of them had working turn signal cancel thingamigiggy's.
Charlie
62' SWB uni 223
66' F-100 Short/wide 352
78' F-350 dually dumpbed 400
12' F-150 5.0 3:73 LS
