alt. light stays on 65 F100
tomrooster
Post by tomrooster »
I hooked up the alt today on my 65 project and it worked fine amp gauge says charging 30 amps but light won't go out till I turn off key. I have a wiring diagram but it don't show the idiot light for charging ,oil light works fine. Thanks for any help. Tom
1966 F 100 w/391 ft
1965 F 100 project
1958 Edsel Pacer Convertible
1953 ford Customline 2 door
1952 8N
1967 triumph Bonneville
Re: alt. light stays on 65 F100
If you are running the original alternator and regulator, the "I" terminal of the regulator needs to be powered from the light circuit with a parallel 15 ohm resistor shunting the lamp wiring at the lamp. If your system is an upgrade, let me know what it is and the current wiring configuration.
tomrooster
Paul, I'm using a 78 alt. with the reg off same using original wires and connectors. Tom
1966 F 100 w/391 ft
1965 F 100 project
1952 8N
tomrooster
Paul , I just checked and I do have 13 volts at the I terminal . Tom
1966 F 100 w/391 ft
1965 F 100 project
1952 8N
If you unhook that wire and turn key on , is that reading from wire or regulator terminal?
tomrooster
wire
1966 F 100 w/391 ft
1965 F 100 project
1952 8N
Kindas a long shot, but check the resistor at the lamp for continuity.
tomrooster
Paul , as a long shot I tried a old regulator that I had laying around but it didn't charge at all so I looked thru my boxes of saved parts (junk) and found 2 more, first one didn't charge like the last one and the next one worked and the amp light went out. Now the original regulator was new that came off the 78 I parted out. Go figure. Thanks Tom
1966 F 100 w/391 ft
1965 F 100 project
1952 8N
